2018 Ford 2.0 EcoBoost
by mpgo4th - 02/28/20 03:30 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
121 registered members (55hambone, 53' Stude, 1978elcamino, 28oz, 762fermeandyou, 4WD, 9 invisible), 2,168 guests, and 16 spiders.
Topics302,049
Posts5,208,023
Members70,825
Real Advantages Of Castrol EDGE 5W30 ? #5186694 08/14/19 07:32 AM
ChrisD46 Offline OP
I am trying hard to take the high road here to better understand advantages of Castrol Edge 5W30 D1 / Gen 2- however that is a bit of a challenge for me to find the hidden "unicorn tears" so to speak of Castrol EDGE . I read all the notable experts here regarding cleaning , NOACK , base oil formulation , OEM specifications met , wear rate , etc. and Castrol EDGE doesn't appear at the top of the list for any ? Of the readily off the shelf synthetic brands - PPPP , M1 , QSUD & Valvoline Advanced 5W30 D1/Gen 2 from what I recall all score higher . My only experience with Castrol EDGE 5W30 was that it was higher priced than any of the above listed synthetic oils at WM and the oil turned black in my 2.4L GDI Hyundai before 1,500 miles (engine has seen nothing but synthetic oil in it since the factory fill 28K miles ago ...) *So what am I missing here about Castrol EDGE 5W30 D1/Gen 2 that makes it worth the extra $3.00 per jug over the 5W30 D1/Gen 2 offerings from SOPUS , Valvoline and M1 ? ... When you compare against QSUD - that makes Castrol EDGE almost $9.00 more per jug ... Is Castrol EDGE really $9.00 per jug better than QSUD ? What attributes am I missing from Castrol EDGE that make it a better choice - other than it turns in a good UOA for fans of the oil ?
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: ChrisD46] #5186780 08/14/19 08:30 AM
Dwight_Frye Offline
I sure hope it is good oil. I decided to use in in my new Mazda CX 5 with the 2.5L turbo engine. It is GF5 and SN Plus rated, meets DEXOS specs and supposedly (according to Castrol anyway) formulated for gas direct injected and turbocharged engines. I bought a 5 quart jug from Amazon for about $23 with free delivery when combined with a couple other items to bring the total up above $25. I wish it were higher in Moly like the Redline 5W-30 that I used to use in my 370Z but then again it isn't $65 for 5 quarts either.
After I get about 10,000 miles on the engine I will run a Blackstone report and see how well it mates with that engine.
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: ChrisD46] #5186872 08/14/19 10:10 AM
T
tenderloin Offline
T
Castrol Edge or Edge Extended? Edge is priced $20.82 5 qt. jug on Amazon. Extended is $24.48 for a 15,000 mile oil. Yes, QSUD is the best price "major" synthetic oil right now. Castrol Edge and Edge Extended are priced right with comparable M1 and Pennzoil offerings..Am I missing something....other than QSUD being .60 less per qt?......Would not be the first time LOL
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: ChrisD46] #5186890 08/14/19 10:29 AM
J
Jimmy_Russells Online Content
Online Content
J
QSUD - Magnatec
PP - Edge
PUP - Edge EP
They set the prices based on these tiers, if you don't compare the same tiers the prices will differ a bit.
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: tenderloin] #5186915 08/14/19 11:01 AM
ChrisD46 Offline OP
*Going by regular , non - roll back WM pricing as my base line (although as you indicated - regular black jug EDGE can be found cheaper elsewhere ) .
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: ChrisD46] #5186922 08/14/19 11:07 AM
SlavaB Offline
My Kia with the same 2.4 turns ANY oil black before 1000 miles, has to do with GDI not the oil
17 Kia Sportage EX 2.4 GDI / Castrol Magnatec 5w30, OEM filter
15 MB GLA250 4Matic 2.0T / Mercedes OEM 5w40, OEM filter
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: ChrisD46] #5186938 08/14/19 11:29 AM
ChrisD46 Offline OP
Perhaps better if I leave out QSUD 5W30 from the discussion and look to compare Castrol EDGE 5W30 Black Jug to PPPP , M1 and Valvoline Advanced 5W30 synthetic oils .
Beyond the fact they all meet D1 / Gen 2 - the only absolutes learned will probably be trying to research a similar engine and driving conditions (i.e. 2.4L GDI Hyundai) to see how Castrol EDGE Black Jug performs ... The rest is mostly marketing and their in - house warlock's special blend of additives ... *Is Mobil still the only oil company who makes their own base stocks or has SOPUS and Valvoline joined Mobil (or continuing to buy base stocks from a 3rd party) ?
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: ChrisD46] #5186951 08/14/19 11:40 AM
O
OilUzer Offline
O
Another good option for you would be Castrol GTX Magnatec 10Wx30. New jugs says full synthetic! Noack 6.9 iirc.
Btw, any oil in 2.4 L GDI Hyundai gets dark quickly. We have one of those. Same any oil in other MPFI engines stays nice & clean. darkness is the gift of gdi.
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: OilUzer] #5187169 08/14/19 04:09 PM
SlavaB Offline
Magnatec 5w30 is the best oil I've tried in my Kia 2.4 so far
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: SlavaB] #5188569 08/16/19 07:42 AM
L
Linctex Offline
L
The 2.4 GDI in my 2013 Kia Optima has 5,000 on the oil change, and it is still a nice medium brown color..??
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: Linctex] #5188584 08/16/19 07:59 AM
SlavaB Offline
The color on the dipstick doesn’t count.
Pull the drain plug and watch the real one smile
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: ChrisD46] #5188669 08/16/19 09:55 AM
1
1bioguy Offline
1
I dont use Castrol at all. I find their advertising insulting and silly, they try to pass themselves off as better than they are. At least more expensive than it should be.
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: Linctex] #5193052 08/21/19 02:24 PM
caprice_2nv Offline
My girlfriend's 2013 Sonata is black shortly after an oil change. She does very short trips so it gets done every 3 months (less than 2k) with cheap conventional at the garage so we have documentation if we need to use the extended warranty on rod bearing failure.
My friend changes oil all day long and says most of the Hyundai and Kias he changes oil on are black on the dipstick before and sometimes even after an oil change. It seems to be the way the GDI engines are.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: Real Advantages Of Castrol EDGE 5W30 ? [Re: SlavaB] #5193061 08/21/19 02:27 PM
caprice_2nv Offline
It's always darker when it's drained out into the pan. You know it's really dark when it's black on the dipstick, but people keep saying color doesn't matter. My opinion is still if it's that dark it looks black on the stick then it's overdue, unless it's a diesel or GDI.
79 Honda CX500
