Put some Bridgestone Potenza SO4 Pole Position tires on the 968 today. Front in 225/45R17 rear in 255/40R17
Replaced some 10+ year old Conti Extreme Contacts that were on the car. The Conti had less then 2k mile on them but the age forced me to change.
Only about 60 miles so far but I can tell the tires needed to be changed, or at least the old ones needed a balance at minimum. Car is much smoother, but I did notice a little bit of tram lining on the way home, hopefully not an issue.
