Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
lr08, BlackMagicVarian, Mustache, mountaingoat, Alegrianyc
71546 Registered Users
21 registered members (Char Baby, 4WD, FordCapriDriver, CATERHAM, 2015Corolla, 6 invisible), 997 guests, and 49 spiders.
Topics305,959
Posts5,283,652
Members71,546
Free wheel oil #5182200 08/08/19 04:09 PM
V
vortex Offline OP
V
Not a free hub an old school freewheel. They call for medium weight oil. But what does that mean?
SAE20 ?
Gear OIL
75W90 ?
75W140 ?
85W140 ?
Currently running the heaviest 85W140 and t seems fine only drawback seems to be that it's way more silent than all the other bikes so people don't hear me coming the gear oil dampens all noise. Haven't really had the pawls slip and it seems to still not get stuck in winter -20C which is a relief but I never did figure out what they mean by medium weight oil.
SAE20 non detergent oil didn't seem to work that well I could hear some level of metal scraping noises and overall it was a bit loud vs the 85W140 that took all the noise away as soon as the freewheel was flooded with it.
85W140 seems to last around 2 years without needing a top off eventually you'll know you need a top off as the ticking noise becomes louder.
Re: Free wheel oil [Re: vortex] #5182280 08/08/19 05:51 PM
L
Linctex Offline
L
Originally Posted by vortex
Currently running the heaviest 85W140 and t seems fine only drawback seems to be that it's way more silent than all the other bikes so people don't hear me coming the gear oil dampens all noise. Haven't really had the pawls slip and it seems to still not get stuck in winter -20C which is a relief .
Sounds like you picked a winner
Re: Free wheel oil [Re: vortex] #5182464 08/08/19 09:37 PM
B
buck91 Offline
B
Phil wood or your favorite gear oil. I like to flush with a light weight oil and then work in the heavy stuff. Apply a little extra and let it rest flat over night .
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Free wheel oil [Re: vortex] #5182549 08/09/19 02:29 AM
K
Kamele0N Offline
K
Chainsaw bar oil.....its sae30 + tackifiers...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Free wheel oil [Re: vortex] #5182775 08/09/19 11:01 AM
CR94 Offline
I've taken freewheels apart and packed the bearings and pawls with grease. Tedious, but lasts much longer than oil. I used to read warnings that that would cause pawls to fail to grip in cold weather, when the grease becomes too thick. However, I've never experienced that hypothetical trouble, using synthetic bearing grease.
2011 Toyota Prius now at 110K
Re: Free wheel oil [Re: CR94] #5183075 08/09/19 06:29 PM
B
buck91 Offline
B
I do this with some higher end freehubs like DT. I do favor lighter greases, though. No issues with the DT Swiss grease and with Slick Honey. Never tried NLGI 2.
Re: Free wheel oil [Re: vortex] #5185809 08/13/19 10:38 AM
N
NYEngineer Offline
N
I like Phil Wood.
Re: Free wheel oil [Re: vortex] #5199823 08/29/19 12:50 PM
N
nthach Offline
N
Phil Wood or Zip Spout oil, ATF even if you can't take it apart. If you can take it apart a thin grease can also be used.
Re: Free wheel oil [Re: vortex] #5199982 08/29/19 03:41 PM
L
Lubener Offline
L
SAE 20 or 30 weight would be fine. Not critical.
The "thinking" man's friend.
Re: Free wheel oil [Re: CR94] #5210329 09/11/19 05:20 PM
Stradbasher Offline
It's not hypothetical at all to those who ride in extreme cold.
