Originally Posted by Fawteen
I choose not to go into a Walmart where urinating on produce is apparently a thing.
Peeing On Taters
I also don't have to worry about used oil being put in a bottle and returned/resold by Walmart. Apparently that has happened a number of times in the past.
I get the oil that I use delivered to my doorstep a few days after I order it, along with filters. I get exactly what I want, and I don't have to deal with the typical unwashed Walmart customers.
Always had trouble believing that. Someone would have to have a tin-foil heat-shrinking machine to replicate the sealed cap.
As far as the produce thing, if it is in a sealed package, same difference, how would they even do it? Open produce, sure, indecent exposure.
And yet in the past there have been a number of discussions on this forum where people have found used oil in containers purchased from Walmart. A real quick search turned up this thread
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=651687
And quite often produce isn't sold in "sealed" packages. In fact, you wouldn't want to put something like a potato in a sealed package-it will rot much faster without any air circulation.
There are a lot of sick people out there, and Walmart just seems to attract the worst of the worst.
I am more with PimTac on this one. You are referring to "used oil in containers." Are you stating that these containers were re-sealed, or just had the open seal and either other liquid or used oil in there and no attempt at re-sealing? The reason I ask, is, if it was re-sealed, then not sure how Walmart or any other retailer would be on the hook if it was made to look like new. Now, if it was the open seal (which is more likely) then that is just negligence on the part of Walmart, though maybe the retailer was told to just accept it back to avoid bad optics, even if the customer was in the wrong. In that case, it should have been checked and not put back out.
As to the produce, you must be referring to fresh and not frozen. There is indecent exposure involved with being able to actually urinate on something in the store, much less that in an irrigated section that is maybe up higher. That is outside the realm of societal norms, I will agree with you that if that was happening at a Walmart and you saw it that there would be nothing loose purchased from there, however PimTac nailed it, this is not common.. I touch the green beans with my hands but I do not pee on anything. It seems relative.
