Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
06 Camry Coolant??
by Jcountry - 02/27/20 07:54 PM
PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
Ford to reduce warranty costs ?
by marine65 - 02/27/20 06:02 PM
hogryder007, Sabbag77, RpR, jameswilliam, Agraz400
70819 Registered Users
67 registered members (alarmguy, 4WD, Astro_Guy, 2015_PSD, 2010Civic, Amkeer, 10 invisible), 1,182 guests, and 17 spiders.
Topics302,027
Posts5,207,529
Members70,819
Page 1 of 3 1 2 3
Optimal oil temp? #5168186 07/22/19 02:08 PM
G
gfh77665 Offline OP
G
I now (finally) own a vehicle that has a digital oil temp display. My 2019 RAM truck with the 3.6 Pentastar V6 has oil temps from 220-225 once fully warmed up and at a highway cruise. What oil temp is desirable for most normally driven vehicles? Is 225 too high? Does it stress the oil somewhat? What is the max temp before oils gets heat damaged? Thanks.
Re: Optimal oil temp? [Re: gfh77665] #5168188 07/22/19 02:10 PM
T
TiGeo Offline
T
My VW 1.8T runs around 210-225...seems v. normal.
2018 VW Atlas SEL 4Motion 3.6 - Castrol OE 5W40 VW filter
2018 VW GSW S 4Motion 1.8 Unitronic St2 IS20 - LiquiMoly 5W40 VW filter+Ceratec/MoS2
2013 Ford Focus SE HB 2.0 - MC syn-blend 5W20 MC filter
Re: Optimal oil temp? [Re: gfh77665] #5168199 07/22/19 02:17 PM
T
The_Nuke Offline
T
Given your location, 220F is pretty normal for daytime driving during the summer. 225F is not too high for the oil, assuming it is a modern SN rated conventional or synthetic oil.
For conventional oils, you do not want to it to see anything north of 275F, as its performance will quickly degrade after that. For synthetics, 300F is the point at which things will start going downhill in a hurry.
However, unless you are running the engine full-out for extended periods of time, its oil should not even approach 275F in temperature. So you can rest easy with the new truck.
Now, if you decide to hook up a trailer with another truck on it and then go try to maintain 65mph up one side of a mountain, you should definitely keep an eye on the oil temps. grin2
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: Optimal oil temp? [Re: gfh77665] #5168226 07/22/19 02:50 PM
B
burla Offline
B
Anything over 212f which is boiling temp. No 225 is not too high at all for a ram.
Re: Optimal oil temp? [Re: gfh77665] #5168242 07/22/19 03:11 PM
A
atikovi Offline
A
You WANT over 212 to boil off condensation. 225 would be ideal.
Re: Optimal oil temp? [Re: gfh77665] #5168287 07/22/19 03:54 PM
Slick17601 Offline
My 201i8Hemi runs the same.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Optimal oil temp? [Re: atikovi] #5168290 07/22/19 03:57 PM
P
Patman Offline
Global Moderator
Global Moderator
P
It doesn't have to be over 212 in order to remove the moisture though, it just gets removed a lot quicker at the higher temps. But if you were to drive all day long and the oil temp only got up to 150F, all the moisture would still be removed, just the same as if you spilled a cup of water on the floor on a 70 degree day, eventually that water would evaporate, and the warmer the temperature it's exposed to the faster it would disappear.
For me, my rule of thumb is that I'd ideally like to see my oil temps be above the 180F mark for a minimum of 15-20 minutes worth of driving.
2018 Corvette, 18k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 154k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,126k, GC 0w40 & Fram Ultra
Re: Optimal oil temp? [Re: gfh77665] #5168343 07/22/19 04:45 PM
Danno Offline
My 2019 Hemi Jeep GC hits 215 - 220 when fully warmed up.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Optimal oil temp? [Re: gfh77665] #5168381 07/22/19 05:56 PM
Quattro Pete Offline
My SRT runs around 220F as well.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Optimal oil temp? [Re: gfh77665] #5168397 07/22/19 06:43 PM
RDY4WAR Offline
I like it to be between 210-230°F. There's other benefits besides evaporating water out of the crankcase. Anti-wear and friction reducing additives, like ZDDP and MoDTC, require heat to activate. The same applies to neutral and overbased detergents. The hotter the oil temp, the more active these additives are.
As far as upper limits, I don't like to see above 260°F resting temperature (pan temperature) with mineral oils. PAO based synthetics can go 300+°F. Something to note is that oil temperature rise through the bearings can increase from 10-80°F above pan temperature depending on the pressure applied and the viscosity / flow. For severe use, it may be beneficial to keep the pan temperature lower than 260°F to compensate for higher bearing temperatures.
The hottest oil I've seen for sustained use is in NASCAR cup engines. They use the equivalent of a 0w-16/20 oil with pan temperatures around 280°F with a 75°F temperature rise through the bearings so the oil exiting the bearings is cooking around 355°F.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Optimal oil temp? [Re: gfh77665] #5168432 07/22/19 07:33 PM
Snagglefoot Online Content
Online Content
Most modern cars have a temperature of about 210 in the water jackets and top part of the radiator. The oil is normally at least this temperature but climbs with rpm. I don’t have the graphs handy but the oil thins out significantly with a rise in temperature induced by high rpm. If you thought the temps were pretty high you would probably want a higher viscosity oil to handle that. Not trying to start a thickie argument. smile
If you want the job done right......do it yourself.
Re: Optimal oil temp? [Re: gfh77665] #5168477 07/22/19 08:32 PM
G
gfh77665 Offline OP
G
The 225 was cruising for 3 hours at 80 MPH through TX and LA in the mid day heat. At 55-60 mph, the temps dropped to the 215-220 range, so I guess its all normal. Even at 80, It never exceeded 225, so most any quality oil must be fine there. Thank you all.
Re: Optimal oil temp? [Re: gfh77665] #5168482 07/22/19 08:37 PM
R
Rand Offline
R
my 2015 forester was routinely in the 216-230 range with extended high speed driving I hit 240f a few times.
Re: Optimal oil temp? [Re: gfh77665] #5168491 07/22/19 09:00 PM
Skippy722 Online Happy
Online Happy
My 300 seems quite content sitting at 190-195, but the van will hit 200-210.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Optimal oil temp? [Re: gfh77665] #5168513 07/22/19 09:25 PM
B
benjy Offline
B
oil temps vary through out the engine + some are quite high! machinery lubrication states for every 10 degrees celcius rise after base oil activation oil life degrades twice as fast!
Page 1 of 3 1 2 3
