Farmall alternator
Northern Michigan
I'm working on an old Farmall bn. I took the old non working generator and put a 10si gm 3 wire alternator in it's place. I'm running new wires to connect it up. The main charging lug I ran to the pos. Wire on the starter. The sense wire I just looked back to the charging stud. The Exciter wire is what my question is. This tractor has a magneto so no key switch or positive wires on the tractor. Just a wire from magneto to a switch that runs to ground to shut the tractor off. Can I just run the sense wire right to the battery or do I need a switch inline that I would have to switch every time I start the tractor to turn on the alternator.
Hook it to the starter solenoid so it will excite the alternator while starting and then won't be powered once the engines running.
Okay I have an idea, get a single throw switch to replace current kill switch (if it is momentary), have switch set so that when it turns on it sends power to the exciter wire. Have the switch also open a relay that is connected to the kill switch wire. That way you wont have to have two switches.
It is also possible to leave the exciter wire disconnected and the alternator should self excite at a certain rpm like a one wire alternator, but on a low rpm tractor motor that might not be a good idea.
I sat down and sketched out how this would be possible without having a relay energized when it is shut down.
Though it IS possible to do this... in the end there are only 2 "simple" options:
1) Just add another switch and wire to energize and be done with it already
2) Sell the good working magneto on Ebay and convert to battery ignition
You really can't "tie in" to the magneto P-lead since IT IS NOT JUST A GROUND wire! It is actually part of the primary ignition circuit.
The sense wire should be connected to +12V connection and can get power all the time. No need to turn on an off but you could. The excite wire needs to be switched on and off with ignition switch. I know magneto but I am just telling you the basics. If you leave excite wire connected all the time the alternator will get warm and drain battery.
A simpler approach is to get what is called a single wire alternator. Only one wire leaving the alternator. Common in hot rods and boats. The alternator does not put out a charge until its RPM is rev'ed up (kick starts it) and from then on it puts out charging voltage.
A rebuild should should be able to convert to a single wire setup.
My 49 C has a single wire GM on it and a "slow speed exciter" in it. I've had the tractor for many years but it was already 12V converted when I bought it. I keep it at my vacation place and won't be back there for a couple of weeks but I can take a look when I go back but I'm pretty sure it is wired as below, there is only 1 single wire leaving my alternator.
alternator to amp meter, amp meter to pull type kill switch, kill switch to battery, then the large cable from battery to starter
I you cant figure it out then you may need some more imagination
The exciter lead is not a ground wire, it needs +12V
Thanks everyone. I think I will just throw a switch in line to the exciter wire. I'll just have to remember the switches. I could also put in a light so I can see when it's on.
