Originally Posted by JTK
Originally Posted by buck91
I tried the plastic line method on a Tahoe... The line blew out every time I started the engine and made a huge mess.
Same thing happened with the 4L60E on a 2005 Trailblazer I owned years ago. The line didn't blow off, but it pumped a 1gal jug full quicker than I could get back into the vehicle and kill the ignition. After that, I try to have a helper stay in the vehicle.
In regards to this process, I wouldn't want to keep the engine idling long if the transmission pumped itself until it's no longer pumping fluid, but like said, I think it would take a while running dry to do pump damage. Just stop when it starts to sputter/bubble to be safe.
What I do to manage this is:
a) Use a long hose from the cooler line I tapped to a position ~4' outboard from the front left wheel. I can see it from the driver's seat and never leave the ignition while I watch an empty gallon milk jug fill.
b) brace the milk jug with a concrete block or such so that the fluid pressure doesn't turn it over. The jug also allow me to easily judge how much fluid has been pumped and turn the car off in time.
c) moving 3qts x 3 will get a healthy percentage of clean fluid into the unit. Way easier than multiple drain/fills over days, raising/lowering the vehicle each time, etc.
This works well for controlling the mess, judging the pump volume, etc. It's a gerotor pump and going to be coated with lube for a while even after suction runs dry - no risk of damage unless you start it and walk away and have lunch or something.
