Summing up, i had a problem with the HEI ignition module of my Kadett, and the engine died a couple of minutes after turning it on in the morning.
The worse part is that when i turned the key , before cranking the engine, i could listen to the fuel pump as i always do, but it was never turning off. I opened the hood and also noticed that the injector was pulsing.
The result is an engine with lots of fuel (ethanol). This scenario (fuel pump and injector sending fuel with the engine off) was only for a cople of seconds (lets say 40s) before i noticed the problem.
I was able to take 200 ml of fuel from the intake (one injector tbi design) by sucking it through the throttle body with a syringe. The intake has the lowest point just beneath the TB, so there is no more fuel at the intake.
I took the spark plugs out and they were dry. Tried to suck something from the inside of the cylinder but there was not a lot of fuel inside to be able to pull out with the syringe.
I know the dipstick reads above the full mark, but cant tell by how much exactly (very clean oil makes it hard to read).
So what is the best thing to do? Consider that ethanol evaporates quickly.
1. Just fix it and change the oil and filter.
2. Just fix it, drain the oil to the full mark and drive the car a few miles before changing the oil and filter.
3. Fix it, change the oil, and crank the engine without the spark plugs to make sure there is no more fuel.
4. None of that, what would yould do?
