Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
lr08, BlackMagicVarian, Mustache, mountaingoat, Alegrianyc
71546 Registered Users
21 registered members (Char Baby, 4WD, FordCapriDriver, CATERHAM, 2015Corolla, 6 invisible), 997 guests, and 49 spiders.
Topics305,959
Posts5,283,652
Members71,546
Page 1 of 3 1 2 3
Downgrade Windows 10? #5137803 06/18/19 07:17 PM
R
Robster Offline OP
R
I have an old ASUS Windows tablet that came with Windows Pro installed on it. I only use it on my reloading bench to look up loading data, listen to iHeartRadio etc. It doesn't need Win Pro, and it has very little left-over drive space. Consequently, it's very slow. I'd like to get the lightest version of Windows 10 that I can, but there doesn't seem to be an easy (free) downgrade path. Any idea how I can accomplish this? NOTE: The Win 10 Pro was installed by ASUS during a repair.
2017 RAM 1500 Big Horn 5.7L:Valvoline AFS 5w-20, Fram TG10060
2019 Hyundai Santa Fe Ultimate AWD 2.4L:Valvoline AFS 5w-20 / OEM filter
2013 Victory Cross Country:Valvoline 4T syn 10w-40, NAPA Gold
Re: Downgrade Windows 10? [Re: Robster] #5137815 06/18/19 07:29 PM
J
jhs914 Offline
J
Have you every tried any of the Linux distributions? If all you are doing is searching for reload data and listening to music it will do fine and is a very efficient operating system, doesn't need much memory or processing power. I have used Ubuntu in the past. It takes some getting used to but if you are computer savvy you can figure it out.
Re: Downgrade Windows 10? [Re: Robster] #5137817 06/18/19 07:30 PM
F
Fawteen Offline
F
There is very little (if any) on-disk space difference between Windows 10 Home and Windows 10 Pro. There are ways to free up space; clean out the temp files, run disk cleanup, etc.
Re: Downgrade Windows 10? [Re: Robster] #5137840 06/18/19 07:51 PM
B
benjy Offline
B
windows 10 stinks IMO windows 7 was best + easiest + i HATE when hovering opens stuff not wanted. so far no luck eliminating that! sometimes there are memory upgrades for small change.
Re: Downgrade Windows 10? [Re: Robster] #5137923 06/18/19 09:12 PM
H
hallstevenson Offline
H
Another comment to say that there's no meaningful disk space usage between different Windows 10 "styles".
Your best bet is to do major house-cleaning. Remove every pre-installed app that Asus includes as a start. Run the disk cleanup tools that are built-in too, including the 2nd phase clean-up. Odds are it has saved a previous version of Windows 10 as a fail-safe backup and this takes multiple gigabytes of space. Get rid of it.
Re: Downgrade Windows 10? [Re: Robster] #5137980 06/18/19 10:31 PM
csandste Offline
Any lightweight Linux distro. Peppermint Linux and Ubuntu Mate are my faves
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Downgrade Windows 10? [Re: Robster] #5138042 06/19/19 12:50 AM
dishdude Offline
I haven't found a Linux distro that runs better than W10.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Downgrade Windows 10? [Re: Robster] #5138046 06/19/19 01:05 AM
R
rubberchicken Offline
R
Can you swap out the existing hard drive for a bigger SSD ? This will make it both faster and give you more space.
Re: Downgrade Windows 10? [Re: Robster] #5138094 06/19/19 05:16 AM
R
Robster Offline OP
R
I've run the clean-up routines. . . as for Linux, I've run Ubuntu on other machines in the past, but I'm thinking that I'd have a problem with drivers for this tablet. I thought there was a "light" version of Win 10 out there--if so, "light" would be perfect for this situation. This tablet has a 32GB SSD and half of it is being used for the OS. Updates (literally) take days sometimes. Thanks for the suggestions!
Re: Downgrade Windows 10? [Re: Robster] #5138123 06/19/19 06:15 AM
T
talest Offline
T
Things like this will help. There are more, but extra settings and needless things make it run slower.
Re: Downgrade Windows 10? [Re: Robster] #5138140 06/19/19 06:42 AM
M
madRiver Offline
M
If you can swap HDD go there.
I run Windows 10 with tweaking tips and bare minimum through paid software called Parallels on a Mac Book Pro(MBP 2017/i5) with limited resources (128GB HDD and 8GB RAM). I think the install of Win 10 Pro(16GB)/Parallels(1GB)/Window App(2GB)/Swap Space(3GB) is under 25GB. Win10 is designed to run decently on barebones on low end computers that compete with low end Chromebooks.
The saving grace of my system is my MBP is the Incredibly fast SSD Hard Drive Apple installs. The likely culprit is a slow outdated HDD.
Re: Downgrade Windows 10? [Re: Robster] #5138299 06/19/19 09:48 AM
R
Rand Offline
R
usually tablets have emmc storage that isnt upgradable
if you need space for music or photos etc you can sometimes use a sdcard or mini usb flash drive.. but that doesnt work for the boot drive.
Re: Downgrade Windows 10? [Re: dishdude] #5138334 06/19/19 10:47 AM
F
FastGame Offline
F
Maybe you didn't look hard enough ?
and
What is does runs better than mean ?
Windows gets smoked vs Linux https://www.google.com/search?clien.....0....1..gws-wiz.......0i71.FhxYV4jvdOY
Re: Downgrade Windows 10? [Re: Robster] #5138484 06/19/19 02:38 PM
H
H
Are you thinking of "Embedded Windows" or something like that ? It's made to run on hardware that generally is used for (1) task (a computer controlling a piece of machinery, for example, or ATMs, etc). If it's that, I'm not sure how to buy a copy or license. Then again, I haven't checked either....
Here it is: Windows (10) IoT (https://www.microsoft.com/en-us/windowsforbusiness/windows-iot)
Re: Downgrade Windows 10? [Re: talest] #5138854 06/19/19 11:00 PM
B
bobdoo Offline
B
In the first video, guy says never to 'defrag' an ssd. Windows 'trims' AND SOMETIMES 'defrags' ssds (something to do with keeping the FAT organised, IIRC. Windows is smart enough to know when to do this. It's a part of maintenance that runs in the background.
He disables automatic Windows Updates. This is moronic. MS is constantly fixing bugs (not even talking about malware, yet), and they distribute firmware updates for devices made by Intel and others. When's the last time anyone here did manual firmware updates for, say, the CPU microcode, or the wifi hardware?
After seeing some of the debloat talk, I stopped watching. That stuff takes up disk space, but makes no difference to most users. (Full disclosure, I have a list of commands to debloat, and I uninstalled a lot of stuff on our 4 main PC's, once. Once.)
The number one tip for faster Windows: go from HDD to SSD (if applicable).
Tip two: get a newer CPU. Clockspeed is king.
Tip three: overclock the CPU (must have a CPU and motherboard that let you do this).
I built an overclocked i7 4790k, on the top Asus board at that time, and have three SSDs in it (OS, OS swap, and Lightroom swap dedicated).
It measures about twice as fast as my new MS Surface Book 2 *laptop*. I notice zero difference in web surfing or spreadsheet use. (Or Room Equalizer Wizard analysis of speaker measurements, a fair CPU hog).
I also have an MS Surface Go, a tiny, full-windows 2-in-1. It measures about 6 times slower than the 4790k, and it actually *is* noticably slowing in loading a dozen Chrome web pages at once, but otherwise feels just as fast while surfing.
If you notice a difference after 'optimizing' your PC, it's almost certainly nothing more than expectation bias.
Page 1 of 3 1 2 3
