- Joined
- Jul 2, 2007
- Messages
- 5,294
by "tuned" I only refer to settings on the smart thermostat. No messing with anything else such as wiring changes to fan speeds.
AC is maintaining indoor humidity @ 45 - 55% range now. I used staging differential threshold (stage 2 lockout) set for 1.5 degrees from thermostat set point and CPH set to 2 to finally achieve my aim: longer run times with the system staying primarily in Stage 1 cooling which is stage 1 compressor mode and low blower fan speed on the air handler. Can hear a satisfying trickle of water from the evap coil drain pipe now. Stage 2 compressor mode still kicks in from time to time and the air handler will ramp up to higher speed I guess when it determines Stage 1 is at 90% load (?...) But so far that's not happening a whole lot and she's remaining in Stage 1 for run times of about 20 - 25 minutes.
Yes, I think the estimator may have slightly over sized us on capacity is why at default settings (Honeywell Prestige IAQ thermostat) it wasn't running long enough to manage indoor humidity efficiently, because it was going right into Stage 2 cooling within minutes of start-up. I knew I had to lock that behavior out, if possible, by playing with the staging differential and cycles per hour (CPH), which seems to have got it done. So far , so good !!
