In simple way, if we increase tyre contact area, then the pressure per mm2 would be reduced. So the friction force per mm2 reduced.
But most Race cars have wide tyres. (Likely to have best possible grip)
Is it because, even if there is enough friction force, sometime the rubber may not have enough strength and would tear. So if there is more contact area, then more rubber will have more overall strength thus we will achieve more breakforce ?
Is there any other reason why wide tyres have better grip ? (If they actually have)
And in wet conditions, may narrow tyres have better grip ? Such as by being able to have better asperity contact with the asphalt ?
