Our 4Runner had Dunlop GRANDTREK AT20 P265/70R17 on it from the factory. I recently replaced them with Michelin DEFENDER LTX M/S 265/70R17.
The Dunlops were 113S and the Michelins are 115T
My question is about the pressures. If I run the Michelins at the pressure on the door sticker, 32psi, the contact patch doesn't fully touch the road, the outside edges of the tread don't touch the road. If I lower them down to 30psi, then they do touch. They are also kind of squirly at 32psi, much better at 30psi!
My question; is running 30psi too low for the tires? The old Dunlops were 300 B B and the new Michelins are 800 A A, so they can handle the heat better than the Dunlops. Am I hurting anything running them that low? I'm guessing that the higher load rating is part of what is contributing to this contact patch issue?
