Bruce Crower Passes
by 02SE. 07/20/19 12:30 AM
Toyota YZZA1 Filter, 9,958mls
by edyvw. 07/20/19 12:06 AM
Chevron Supreme 5w30 Noack?
by Whammo. 07/19/19 11:56 PM
Injector sleeves in 7.3 Powerstroke w/ 6 sp MT
by Earls1st. 07/19/19 11:32 PM
Which 0W20 to slow use
by lukejo. 07/19/19 11:09 PM
2012 Camry suspension question
by lukejo. 07/19/19 11:03 PM
Opinions on manufactured homes
by ram_man. 07/19/19 10:50 PM
NGK Ruthenium HX
by David1. 07/19/19 10:21 PM
Royal Purple Filter Mileage Rating
by JerryBob. 07/19/19 09:53 PM
what brand of filter is this?
by ctwhitechin. 07/19/19 09:45 PM
VW Amorak truck
by AZjeff. 07/19/19 09:25 PM
New Honda Super Cub - leaking oil
by Lawn_Care. 07/19/19 08:55 PM
Loc-n-lube
by rideon. 07/19/19 07:54 PM
Humidity thread follow-up... phew!
by 14Accent. 07/19/19 06:55 PM
NEW FEDERATED LF651F FILTER CUT OPEN
by 53' Stude. 07/19/19 06:39 PM
Brake Job @ 26K On My GLC43
by 2015_PSD. 07/19/19 06:25 PM
New Scanner Autel MK808BT
by another Todd. 07/19/19 06:20 PM
Stonehunter, ctwhitechin, gwandless, Philippe1988, ChiefDaBooty
68712 Registered Users
31 registered members (CleverUserName, chrismo, c1vic, DrDave, csandste, 5 invisible), 710 guests, and 27 spiders.
Topics292,124
Posts5,017,194
Members68,712
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Top Tier gas #5124551
06/03/19 08:46 PM
06/03/19 08:46 PM
PV Az @ 5000'
AZjeff Offline OP
AZjeff  Offline OP
PV Az @ 5000'
I like using TT gas but the stations in my area with it are out of my way and a bit inconvenient to get to. I fill up the RAV4 once a week. Thoughts on how often I should get a tank of TT so the added detergents will keep things clean?
Is TT even needed in DI engines?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Top Tier gas [Re: AZjeff] #5124573
06/03/19 09:06 PM
06/03/19 09:06 PM
Texas, USA
PPWarrior Offline
PPWarrior  Offline
Texas, USA
Toyota uses both DI and Port Injection. You can get by. If you want to shake things once in a while, you can always put a bit of Techron or any other cleaner in ther.e
nissan versa m/t
chevy imapala auto
toyota corolla auto
Re: Top Tier gas [Re: AZjeff] #5124656
06/03/19 10:33 PM
06/03/19 10:33 PM
Far East Side
DoubleNickels Offline
Far East Side
Some people believe that "top tier" is just a marketing gimmick.
Re: Top Tier gas [Re: AZjeff] #5124657
06/03/19 10:34 PM
06/03/19 10:34 PM
PV Az @ 5000'
AZjeff Offline OP
AZjeff  Offline OP
PV Az @ 5000'
The 14 RAV is normal induction, I was also thinking about the 18 Titan with the 5.6 DI engine.
Re: Top Tier gas [Re: DoubleNickels] #5124665
06/03/19 10:44 PM
06/03/19 10:44 PM
Southeast Texas
gfh77665 Offline
gfh77665  Offline
Southeast Texas
They are wrong.
Re: Top Tier gas [Re: AZjeff] #5124671
06/03/19 11:03 PM
06/03/19 11:03 PM
St. Charles County, Missouri
csandste Online content
csandste  Online Content
All the time unless you're out of gas and there's nothing in walking distance.
2017 Kia Soul Plus-- VWB 5w30 65,000 miles
Re: Top Tier gas [Re: AZjeff] #5124684
06/03/19 11:22 PM
06/03/19 11:22 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
You should do it all the time, so that you don't necessarily have to buy a bottle of Techron, Gumout Regane, etc every 3000 miles.
You can plan your gas stops around your schedule.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Top Tier gas [Re: PPWarrior] #5124687
06/03/19 11:25 PM
06/03/19 11:25 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
2AR-FE is Port Injection only.
Re: Top Tier gas [Re: AZjeff] #5124789
06/04/19 06:20 AM
06/04/19 06:20 AM
California
Ed_Flecko Offline
Ed_Flecko  Offline
California
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Top Tier gas [Re: AZjeff] #5124818
06/04/19 07:16 AM
06/04/19 07:16 AM
SE PA
diyjake Offline
diyjake  Offline
SE PA
I always try to use Top Tier gas and I really do believe it makes a difference.
Re: Top Tier gas [Re: DoubleNickels] #5124822
06/04/19 07:23 AM
06/04/19 07:23 AM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
This 👇...i won't use anything but TT.
https://clark.com/cars/top-tier-gas-stations-clean-engine-aaa/
Re: Top Tier gas [Re: AZjeff] #5124831
06/04/19 07:26 AM
06/04/19 07:26 AM
NE Florida
Throt Offline
Throt  Offline
NE Florida
I haven't purchased non-TT gas in years. TT only in my cars. Though, in these DI days, not sure what good it's doing since it never hits the valves. The Honda in my sig is only DI, not a combo of DI and PI.
'18 Honda Accord Touring, 1.5T, 11,100mi, PPPP 5w30 w/ FU
'19 Elantra, 2.0L, 700mi, FF/Filter, hers (lease)
Re: Top Tier gas [Re: DoubleNickels] #5124875
06/04/19 08:11 AM
06/04/19 08:11 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
And some people think oil thickens as the temperature increases.
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: Top Tier gas [Re: UG_Passat] #5124893
06/04/19 08:38 AM
06/04/19 08:38 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I've been running top tier Irving. Seems more consistent than most around here.
Get Swamp water Here and there with the E10.
Top Tier doesn't preclude garbage gasoline
Still have to run a 1/2 bottle of Gumout Regane every 1500 in the VW.
In my Geo area Shell has been abysmal for decades. Top tier or no.
2019 VW Jetta S 6MT OCI#0 5033mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: Top Tier gas [Re: AZjeff] #5124943
06/04/19 09:49 AM
06/04/19 09:49 AM
Lakeville, MN
MNgopher Offline
MNgopher  Offline
Lakeville, MN
When nearly all retailers here offer Top Tier Gas at the same price as non-top tier, which one do you think I choose?
Its too bad that with the sale of Superamerica and the rebranding to Speedway here, they removed their top-tier gasoline. Used to be some of the best bang for the $ gasoline here (in terms of observed Octane Adjustment Ratio in my Ecoboost F150) (And yes, since they owned their own refinery at the time, and had their own distribution, it was different gasoline (and still is) Other markets are different.)
The other big players here (Kwik Trip, Holiday, Shell, BP, and in outstate Cenex) are all Top Tier rated...
Page 1 of 4 1 2 3 4
