Vintage Sinclair promo
by HiPowerShooter - 02/18/20 11:29 PM
why did my Ford iolm go to 9% after 3k miles?
by dogememe - 02/18/20 11:15 PM
HUBB reusable stainless steel filter?
by Vern_in_IL - 02/18/20 08:41 PM
Ultrasonic carb cleaning problems
by atikovi - 02/18/20 08:05 PM
Cheeseburger pie
by P10crew - 02/18/20 07:25 PM
The midwinter detail.
by dan_erickson - 02/18/20 05:27 PM
Tired of Using Cassette Player with iPhone
by Gebo - 02/18/20 05:04 PM
STP oil filter
by Stinky123 - 02/18/20 04:41 PM
How is this possible
by V10 - 02/18/20 04:07 PM
Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
GardenStateAudi, Strommen95, Idaholewis, Sprite, spbonus
70746 Registered Users
41 registered members (carlprop, bbhero, blufeb95, 2strokeNorthstar, 928, Blkstanger, 3 invisible), 1,289 guests, and 19 spiders.
Topics301,631
Posts5,199,530
Members70,746
94 mazda b4000 diff fluid #5116864 05/26/19 10:08 PM
H
HyundaiAbuser Offline OP
H
Hey guys I'm looking to change the differential fluid in my 94 b4000 but I cannot find the owners manual. If y 'all have any suggestions as to what is oem or what can work that would be fantastic.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Supertech 5w30 Full Synthetic
Valvoline Dex/Merc
Re: 94 mazda b4000 diff fluid [Re: HyundaiAbuser] #5116872 05/26/19 10:35 PM
cos Offline
From the Amsoil Lookup Guide: "GL-5 All TEMPS....80W-90"
'15 Cadillac SRX
- Castrol Magnatec 5W30
- Valvoline Maxlife ATF
Re: 94 mazda b4000 diff fluid [Re: HyundaiAbuser] #5116888 05/26/19 11:07 PM
Chris142 Offline
Isn't that just basically a ford ranger?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 94 mazda b4000 diff fluid [Re: HyundaiAbuser] #5116897 05/26/19 11:27 PM
O
oldhp Offline
O
Any 75W90 syn will work fine too.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: 94 mazda b4000 diff fluid [Re: HyundaiAbuser] #5116993 05/27/19 06:23 AM
A
atikovi Offline
A
[Linked Image]
and RTV for the cover
[Linked Image]
Re: 94 mazda b4000 diff fluid [Re: HyundaiAbuser] #5117137 05/27/19 09:04 AM
H
H
thanks guys im planning on doing it when my rtv comes in tomorrow
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: 94 mazda b4000 diff fluid [Re: HyundaiAbuser] #5118228 05/28/19 01:07 PM
01rangerxl Offline
80W90, but really anything that is GL5 gear oil is fine.
I have Sta-Lube 80W90 in the front and rear diffs on my '94 Ranger because it came in a convenient gallon jug. My '02 has synthetic Valvoline 75W90 in it. Ford specified 75W140 for many 8.8s, and I have used that too. I'm going to change the front & rear diff fluid in my '94 Explorer soon and will use whatever 80W90 I find in a gallon container...Coastal, Sta-Lube, etc.
If the truck has a limited slip diff, you need to make sure to use friction modified fluid or buy an additive. You can find out if it is limited slip from the axle code on the door jamb.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
