das_peikko
Thread starter
Originally Posted by The Critic
From your background, I thought you had a basic understanding of how a vehicle's suspension system works...
From what Scotty Kilmer says, there's rubber in the mount where the center rod protrudes through. When that rubber wears out, the strut rod will no longer stays centered; causing alignment issues and noise. Mine are in good shape from what I can tell, but was considering replacing the mounts anyway as preventative maintenance. I may hold off while I verify that all the aftermarket mounts are garbage. So far, I've read complaints about both KYB and Moog on Amazon, but I can't find any reviews on Sachs.
