Toyota WS UOA and Redline D6 VOA
by Patrick0525. 06/19/19 04:28 PM
2015 4Runner UOA w/ TGMO ALUMINUM
by OCDoiler. 06/19/19 04:17 PM
Evinrude oil
by FastLane. 06/19/19 03:40 PM
engine air filters...all the same?
by flinter. 06/19/19 03:37 PM
GM Dexron Developer Passes Away
by MolaKule. 06/19/19 03:20 PM
Hard Tonneau Cover Clean/Protect
by jims5600. 06/19/19 03:17 PM
2006 Camry 4 cyl. 15,000 miles on M1 5W-30
by Deontologist. 06/19/19 02:29 PM
puma oil nissan 350z? 20w50
by 1978elcamino. 06/19/19 02:04 PM
PL14612 cut open, ~5100 miles
by Sayjac. 06/19/19 01:42 PM
Best ATF for vintage Toyota P/S system
by timoboy. 06/19/19 01:16 PM
Touchless 303 thoughts?
by DriveHard. 06/19/19 12:59 PM
Napa Conventional 5qt @ $11.99
by SlavaB. 06/19/19 12:53 PM
Just spotted: 1974 Pinto!
by dadto2. 06/19/19 12:49 PM
Steering Rack Quality
by LazyDog. 06/19/19 12:43 PM
Liquid lawn fertilizer
by LeakySeals. 06/19/19 12:01 PM
HynKia Carquest filters: 85334 vs 95459
by SlavaB. 06/19/19 11:26 AM
Shell Spirax S1 alternatives
by avacado11. 06/19/19 10:38 AM
ZF HP8 Transmission Servicing
by Joel_MD. 06/19/19 08:50 AM
HF flashlight recall = 5 dollar gift card
by 1978elcamino. 06/19/19 08:41 AM
taschnewitz, SilverFL, CactusLady, Ignatius, Kyle_O
68434 Registered Users
109 registered members (2oldtommy, AandPDan, 2015_PSD, 2K2AcuraTL, 1978elcamino, 15 invisible), 2,200 guests, and 26 spiders.
Topics290,671
Posts4,990,654
Members68,434
Most Online2,967
Mar 10th, 2019
M1 EP for '19 F150 3.5 EB #5116185
05/26/19 10:02 AM
05/26/19 10:02 AM
FL
dseg42 Offline OP
dseg42  Offline OP
FL
I usually run Amsoil SS but due to it being a new truck and wanting to keep it under the powertrain warranty and lower cost, I was going to switch to M1 EP with the M1 oil filter.
The 2019 F150 isn't on Mobil1's website, any reason I can't use 5-30W M1 EP for this Ecoboost truck?
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116216
05/26/19 10:36 AM
05/26/19 10:36 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Why would you want to?
2015 F150 2.7
2018 F350 6.2
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116234
05/26/19 10:55 AM
05/26/19 10:55 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Good choice. 5W20 is generally put there for fuel economy reasons, that really don't increase mileage one mile per gallon anyways. 5W30 is better for TGDI/GDIs, as many automakers have recommended it over thinner owners manual recommendations in prior years.
Exxon-Mobil generally abides by the owners manual recommendations. Tha't probably why it's not there on the website. Plenty of members here have found better results using 5w30 in that engine.
At $3 per gallon at the gas pump, you may endure a $5 increase when filling-up (very large fuel tank). The trade-off is a better sounding, performing and lasting engine.
Just my opinion, as I know two F150 owners using that engine. One still stands by the 5w20. But he's the type that goes by owners manuals 100%. He even still uses Remington oil, Remington cleaner and Remington 30-06 ammo in his Remington 7400/7600? deer rifle. Yes, he's found better results using my 2nd party ammo, cleaner and oil, but still won't change..... why?..... because it's listed as the preferred choices in that owners manual.
Some folks never change - not even for the better......Whatever!
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116260
05/26/19 11:18 AM
05/26/19 11:18 AM
NJ
buster Offline
buster  Offline
NJ
I would run any of the Mobil 1 5w20's. All of them are very good.
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116264
05/26/19 11:25 AM
05/26/19 11:25 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
On the other thread you started, we discussed the required specification for your engine. Does the Mobil 1 EP product carry that?
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116272
05/26/19 11:32 AM
05/26/19 11:32 AM
Council Bluffs
GaryPoe Offline
GaryPoe  Offline
Council Bluffs
Its an EcoBoost truck he said, so the recommend oil is 5w30.
2014 F150 STX 4x4 Sport, Super Cab 5.0L Coyote, OZ Omega Tuned, Leveled with 35" BFG TKO2, Banks Power Monster exhaust, jlt oil seperator 5w20 PPPP, Motorcraft fl-500-s
Re: M1 EP for '19 F150 3.5 EB [Re: GaryPoe] #5116273
05/26/19 11:33 AM
05/26/19 11:33 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
The grade recommendation is not the specification. That's what ExxonMobil is going to key off of on their website.
1994 BMW 530i, 242K
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116285
05/26/19 11:42 AM
05/26/19 11:42 AM
Council Bluffs
GaryPoe Offline
GaryPoe  Offline
Council Bluffs
The specification of the EcoBoost is M2c946B1 which is 5w30. If the oil has that spec, its fine for your engine.
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116288
05/26/19 11:45 AM
05/26/19 11:45 AM
New York
pbm Offline
pbm  Offline
New York
If you don't plan on doing extended OCIs (which I consider to be over 7K miles)...regular M1 in the recommended viscosity should work fine....the same can be said for virtually every synthetic sold at Walmart.....In other words....even Supertech syn. should work well for a 7K OCI....
'Journalism is Dead'
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116295
05/26/19 11:50 AM
05/26/19 11:50 AM
NJ
buster Offline
buster  Offline
NJ
Ah for a 5w30 I'd use any 5w30 from Pennzoil Platinum, Castrol Edge 5w30, regular M1 5w30 or Mobil 1 EP/AP 5w30. Can't go wrong with any of those.
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116305
05/26/19 11:58 AM
05/26/19 11:58 AM
FL
dseg42 Offline OP
dseg42  Offline OP
FL
Thanks for the feedback.
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116331
05/26/19 12:30 PM
05/26/19 12:30 PM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
There are over a 100 3.5 Ecoboosts in the fleet we maintain and for 8 years in this environment of dusty, idle for hours, WOT for miles, conditions which are just insane for an engine each engine get serviced at 5K miles with bulk lowest bidder API SN motor oil and oil filters. 5K miles could and often does equal over 500 hours of service so it's severe. There has been 0 lubercated related failures.
M1EP is way too much Overkill for factory recommended OCI's just FYI.
don't use.
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116339
05/26/19 12:42 PM
05/26/19 12:42 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
With the potential fuel dilution issues that the 3.5 ecos have , look up the posted uoas. Shorter oil change intervals may be prudent if we are going to be anal about it. I don't see advantages of long life oils is shorter oil change intervals. We have people regurgitating 5/20 on a 3.5 eco seriously?Link to view.
2015 F150 2.7
2018 F350 6.2
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116515
05/26/19 04:56 PM
05/26/19 04:56 PM
FL
dseg42 Offline OP
dseg42  Offline OP
FL
Any reason to go with Annual Protection vs Extended Performance?
Re: M1 EP for '19 F150 3.5 EB [Re: dseg42] #5116543
05/26/19 05:32 PM
05/26/19 05:32 PM
Council Bluffs
GaryPoe Offline
GaryPoe  Offline
Council Bluffs
15k oci ep vs 20k oci ap.
