Hello, I have some gear lube questions. I was trying to find the answers in my owners manual and from the Ford website. I have a 2011 Ford Ranger. 4.0v6, 5R55E automatic, 3.55:1 open 8.8 rear, 2WD. The manual says to use 80W-90 in the differential and it says how much to use. What I do not see is how often Ford says I should change it. What is the OEM drain interval for my rear differential? Thank you for the help.
