6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
talk to me about security cameras
by 1978elcamino - 08/21/19 03:30 PM
modem in 1 room want phone in another room
by raaizin - 08/21/19 02:17 PM
AC Belt Question
by BISCUT - 08/21/19 02:10 PM
Pros and cons of Electronic Parking Brakes?
by KGMtech - 08/21/19 01:50 PM
Got my first BS sample kit - now what?
by ARCOgraphite - 08/21/19 01:00 PM
2016 Mazda6: no belt replacement interval
by Elkins45 - 08/21/19 01:00 PM
Replaced alternator but kept belt
by Deontologist - 08/21/19 12:51 PM
NapaGold 1348 c&p, 7+yr.OPE fci.
by Sayjac - 08/21/19 12:38 PM
Toyo Proxes ST3
by Redright9 - 08/21/19 12:20 PM
Do you trust air filling stations?
by walterjay - 08/21/19 12:10 PM
Someone explain this part of youtube.
by atikovi - 08/21/19 10:48 AM
Help choosing suspension/steering parts '04 Ranger
by Patrologia - 08/21/19 10:43 AM
2006 V8 Sequoia 264K M1 5w30; 7700 miles on oil
by claluja - 08/21/19 09:48 AM
Meguiars Hyper Dressing
by buster - 08/21/19 09:46 AM
Is it really M1 ESP X1 0W30?
by 21Rouge - 08/21/19 09:33 AM
WWYD? Battery Choice - 2015 Canyon
by WylieCoyote - 08/21/19 09:27 AM
Bypass Orifice
by Bailes1992 - 08/21/19 09:23 AM
Sissen, Luke352, drh214, Levinz11, tequilla50
69019 Registered Users
85 registered members (2015_PSD, aquariuscsm, Astro14, ARCOgraphite, 12 invisible), 2,182 guests, and 24 spiders.
Topics293,612
Posts5,043,462
Members69,019
Most Online3,532
Jul 30th, 2019
212cc Dodge Ram D50 - 20 mph #5103962 05/13/19 06:20 AM
L
Linctex Offline OP
L
What this guy REALLY needs is one of the big Harbor Freight V-twin engines!
https://jalopnik.com/wrenching-hero-installs-120-lawnmower-engine-into-dodg-1834692410
Wrenching Hero Installs $120 Lawnmower Engine Into Dodge Ram Pickup
What we’re looking at here is an early 1980s Dodge Ram 50 powered by a 6.5 horsepower, 8.1 ft-lb overhead-valve single-cylinder engine sold at Harbor Freight for $120.
The Dodge had apparently been sitting in the young wrencher’s friend’s yard for a while, so the friend just gave it away. Carson Duba decided to have some fun with it, stripping out the old motor, leaving not much more than the steering intermediate shaft and brake master cylinder. He then built a platform that ties into the original engine mounts, and that carries the single-cylinder engine.
That engine, which can slide on the platform thanks to slotted holes, has a centrifugal clutch on its output shaft, which sends power to a five-speed manual transmission via a sprocket and a chain. To get a 60-tooth sprocket on the transmission end, the YouTuber welded a shaft to the transmission input shaft (unsurprisingly, it was difficult to weld it perfectly straight), and then made a bracket so that the shaft could ride on a bearing (this bracket ties into a custom mount that holds up the front of the transmission). The big sprocket sits on the end of that shaft, and the tension of its chain is set by sliding the motor along the slotted holes in the platform.
The whole build is far more elegant than I expected for something as silly as a lawnmower in a junky old truck. The choke is hooked up to a nice slider on the dash, the original cable running from the gas pedal actuates the tiny engine’s throttle, and there’s a fairly nicely-packaged pull cord that goes through the fender, with a handle in the wheel housing that starts motor. A simple kill switch on the dash cuts it off.
The young mechanic even made his own door panels using material from a shower, and he demonstrates in the video that the truck works in both reverse and in a forward gear, even if it only drives about 20 MPH.
Re: 212cc Dodge Ram D50 - 20 mph [Re: Linctex] #5103989 05/13/19 07:12 AM
A
andyd Offline
A
The Predator is used in go carts and can be modified for more oomph Thanks for a good read, Linctex grin2
Thick oil is better grin2
Re: 212cc Dodge Ram D50 - 20 mph [Re: Linctex] #5104065 05/13/19 09:25 AM
Bud_One Offline
Projects like these are awesome thumbsup
16 Civic-QSUD 0W-20, XG7317
14 Civic-PP 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, PF61E
97 Accord Wagon-Napa Performance 5W-30, Napa 21334
Re: 212cc Dodge Ram D50 - 20 mph [Re: Linctex] #5104085 05/13/19 09:47 AM
Chris142 Offline
I had one of those trucks.Pure trash from the start. The predator engine is likely better than the 2.6L Mitsubishi it came with.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: 212cc Dodge Ram D50 - 20 mph [Re: Linctex] #5104094 05/13/19 09:55 AM
Z
zorobabel Offline
Z
Perfect for rush hour traffic smile
1997 Maxima 206k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 205k, VWB 5W-20-30, MGL4967
Re: 212cc Dodge Ram D50 - 20 mph [Re: Linctex] #5104100 05/13/19 10:03 AM
J
joegreen Offline
J
It looked pretty torquey. Would make a good yard truck and be super reliable. Easy to work on, cheap to maintain.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: 212cc Dodge Ram D50 - 20 mph [Re: Linctex] #5104115 05/13/19 10:21 AM
R
Rand Offline
R
If I was going to that much trouble I would have gotten the 22hp HF V-Twin engine or at least the 13hp 420cc
Re: 212cc Dodge Ram D50 - 20 mph [Re: Rand] #5104155 05/13/19 11:29 AM
L
Linctex Offline OP
L
Yes, EXACTLY
Re: 212cc Dodge Ram D50 - 20 mph [Re: joegreen] #5104156 05/13/19 11:30 AM
L
Linctex Offline OP
L
Yep, and about $9,000 cheaper than so many name brand "side-by-sides" that I see
Re: 212cc Dodge Ram D50 - 20 mph [Re: Rand] #5104272 05/13/19 01:30 PM
dogememe Offline
Easy enough to do an engine swap down the road, all the hard stuff is already done. I doubt that engine is gonna last a long time anyway, a lot is being asked of it to pull around a Dodge.
2010 Ford Escape 2.5 ~98K Miles
Valvoline 5W-20 from Valvoline Instant Oil Change.
Re: 212cc Dodge Ram D50 - 20 mph [Re: Linctex] #5104791 05/14/19 03:04 AM
Silk Offline
Dodge ? crackmeup It's a Mitsubishi L200.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: 212cc Dodge Ram D50 - 20 mph [Re: Linctex] #5104821 05/14/19 05:45 AM
Shannow Online Content
Online Content
If it's the truth....it can handle the pressure !!!
