98 Expedition 5.4 4x4 4R100 tranny.
I want to do a transmission fluid change on my Expedition. I would like to change as much of the system fluid as possible without flushing and without using high pressure. I had a big mess yesterday with transmission fluid leaking out from a hose clamped on to transmission cooling lines bypassing the radiator transmission cooling tank and would like to have a more controlled method other than starting the truck and pumping it out with high pressure.
Any advice how to change more than the pan fluid?
Anyone know which is the high pressure line the upper or lower cooling line?
Anyone know how much just the pan holds?
