83 registered members (1foxracing, 77GrandPrix, Aero540T, alcyon, adams355, 53' Stude, 6 invisible),
1,658
guests, and 20
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,792
Posts5,141,184
Members70,123
Most Online3,589 Nov 2nd, 2019
Re: under valve cover pics 363k miles
[Re: bullwinkle]
#5092401
05/01/19 05:52 AM
Ed_Flecko
Posts: 829 |
It is a Panther chassis, there are many Crown Vic PIs that went through police service & have ran big miles in taxi service (which I'm guessing is the case here?).
You are correct. The Crown Vic is a surprisingly durable car!  Ed
K-9s teach the suspect that if you run...you'll only be arrested tired. Support YOUR local law enforcement K-9 Unit! https://www.ssdk9.com/
[Re: Dubai_guy]
#5092411
05/01/19 06:01 AM
atikovi
Posts: 3,288 |
Towncars use that engine and limos routinely go 400 or 500K miles. There was one on Ebay a while back with over 700,000 miles.
[Re: double vanos]
#5092416
05/01/19 06:07 AM
Miller88
Posts: 13,755 |
I thought everyone in Dubai ran 20w50 in everything! On a more serious note - looks good. How's the interior holding up? Does it all crack? M/C did a good job! It looks like the passenger side had a little more varnish than the drivers side. Hotter on that side maybe? I believe that's the oil pumps through the driver's side first then to the passenger side head. The oil passages on that side are very small, too.
18 Forester 2.5I 6M 00 Jeep XJ 01 F-350 4x4 5M
[Re: bullwinkle]
#5092447
05/01/19 06:45 AM
ford46guy
Posts: 589 |
My main question is-are they the original timing chains & guides? Also, why did the cam need to come out? Valve seal replacement? No need to remove cams for VS seals., I did it on my Tbird (pretty much exact engine under the intake manifold). There is a tool to tilt the valves. That mileage isn't spectacular. I know some cabs upstate here pushing 500K. Original everything. They are 98-02 (you can tell by the dished wheels). The transmissions have the drain pan with the plug.
95 Tbird V8 240K PP SYNTH ULTRA 5W30 98 MGM 160K M1 HM 5W20 96 Explorer EB V6 159K PP SYNTH HM 5W30 95 Conti 155K MC 5W20 11 GS350 90K PP HM 5W30
[Re: Dubai_guy]
#5092466
05/01/19 07:09 AM
ZZman
Posts: 6,782 |
I only have 151,000 miles on my GM 4.6. Are you telling me I can never get rid of this car as it will run forever?
2007 Hyundai Santa Fe AWD. 2005 Toyota Avalon XLS
[Re: Dubai_guy]
#5092486
05/01/19 07:30 AM
emmett442
Posts: 287 |
Passenger side is the "dirty" side of the PCV system. All of the vapors and blowby flow through that side, hence the darker color. Driver's side is the clean side, which only sees air from the filtered air intake pulled through it. Difference in color between banks is normal.
2011 Ford Crown Victoria LX 4.6L V8 auto 2009 Chevrolet Malibu LT 2.4L I4 auto 1974 Dodge D200 360 V8 4 speed manual
[Re: Dubai_guy]
#5092551
05/01/19 08:25 AM
PimTac
Posts: 11,783 |
The op has 363,000 miles on this car yet some try to downplay it. Only on BITOG.
Looks good.
2017 Mazda CX5 Havoline Pro DS 0w20 Roki OEM filter.
[Re: Dubai_guy]
#5092552
05/01/19 08:26 AM
Y_K
Posts: 2,640 |
Keep in mind that fuel formulation there is different from ours in the States. I have never saw a Police Inerceptor in taxi service after police abuse going over 250k on 5-20 without smoking. The OP has been doing very well. Just keep your eye on the rear axles and bearings: that year had some bad ones, and the design is half-assed
[Re: Y_K]
#5092564
05/01/19 08:36 AM
emmett442
Posts: 287 |
Just keep your eye on the rear axles and bearings...and the design is half-assed
Design is half assed? Based on what? It's the exact same design as every other semi-float axle over the last century.
[Re: emmett442]
#5092568
05/01/19 08:40 AM
Ifixyawata
Posts: 757 |
Design is half assed? Based on what? It's the exact same design as every other semi-float axle over the last century. Leaf springs are more safe and reliable. No need of new-fangled 'coil springs' or 'control arms'. /s
2004 Mercury Mountaineer 4.6 M1 High Mileage 10w-40 (Summer) 2001 Ford Focus 2.0 Zetec Pennzoil Euro L 5w-30
[Re: PimTac]
#5092569
05/01/19 08:41 AM
Ifixyawata
Posts: 757 |
Looks good. Could be at 500k by now if 10w-40 was used.
[Re: Dubai_guy]
#5092586
05/01/19 08:54 AM
JLTD
Posts: 3,062 |
Looks like normal wear...seal it back up and go for another 363!
I use the overseas manual to choose my viscosity.
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil Looking at options.
His: 2015 4Runner 60k, SS 5w20/Amsoil
[Re: Dubai_guy]
#5092609
05/01/19 09:15 AM
csandste
Posts: 2,645 |
Combo of old style, lazy large displacement engines and new oils (even with some group II) are a combo that will allow you to drive forever. Nice!
2017 Kia Soul Plus-- VWB 5w30+ a bit of Harvest King syn 5w30-- 70,000 miles
[Re: Dubai_guy]
#5092612
05/01/19 09:17 AM
KrisZ
Posts: 9,159 |
Looks very good. Thanks for sharing.
2015 Grand Caravan 3.6L - 31k miles. 2006 Mazda 3 2.0L - 171k miles
[Re: csandste]
#5092638
05/01/19 09:54 AM
Lolvoguy
Posts: 3,451 |
Combo of old style, lazy large displacement engines and new oils (even with some group II) are a combo that will allow you to drive forever. Nice!  The high-strung, ubiquitous 1 and 2 point whatever, turbo(and super)-charged engines of today will NEVER reach these miles without at least one complete rebuild.
06 Lexus IS350- Wife 88 BMW 325is- Mistress Say "no" to Turbo!
