Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
Should I run an AC Delco Ultraguard gold?
by JHZR2 - 11/17/19 01:13 PM
Ford Ecoboost 400 at Homestead Miami Speedway
by bdcardinal - 11/17/19 01:08 PM
Strut mount, Moog vs KYB?
by jbutch - 11/17/19 01:07 PM
Is bar and chain oil hard on rubber?
by jqgz - 11/17/19 12:53 PM
TSC - Mobil Delvac $10.99
by Greg L - 11/17/19 12:42 PM
Wifi Thermostats
by FA_WRX - 11/17/19 10:33 AM
Test drove a few trucks. Ram Pentstar V6?
by dja4260 - 11/17/19 10:15 AM
2010 Corolla LE Opinions
by maverickfhs - 11/17/19 10:06 AM
2019 Toyota Highlander LOTS of metal flakes
by Mathew_Boss - 11/17/19 09:46 AM
Blaster Sidekick
by buster - 11/17/19 09:27 AM
2009Caraman, redmonkey01, gnouhp, tiblow, Gruenmeister
69895 Registered Users
116 registered members (A310, 4WD, 69Torino, 379KITTY, 92saturnsl2, 2002 Maxima SE, 9 invisible), 2,311 guests, and 23 spiders.
Topics297,556
Posts5,117,965
Members69,895
Most Online3,589
Nov 2nd, 2019
2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi #5084464 04/24/19 06:27 AM
J
jayjr1105 Offline OP
J
Thought I'd share this UOA from last year. Opinions welcomed, I'm still new to all the numbers and different materials.
This is the 2.0L Skyactiv motor.
[Linked Image]
2013 Mazda 3 - Supertech FS 0w20
2005 Honda Odyssey - Supertech FS HM 5w20
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: jayjr1105] #5084603 04/24/19 09:15 AM
O
oil_film_movies Offline
O
The silicon number not being over about ~25 ppm means the air filter path is sealed up and not allowing silica dust into the engine, so that's good news to know. All the numbers look decent really.
Iron is only a touch higher than it should be. Try using a Fram Ultra oil filter for better filtration, the best filter around to catch more, so it might help some. The Fram.com website says you have to be careful which oil filter you get since they changed the oil filter thread size in the middle of the model year.
https://www.fram.com/parts-search/?...BkAWAAlwDp8mymBLMAAsALmwAi6EQE8yAKhABdIA
Then I'd recommend M1 AFE 0w30 from now on (another walmart item like the fram ultra oil filter). That's 10% more HTHS viscosity for these slightly older engines and it could lower the wear numbers.
Your ending viscosity wasn't excessively low, meaning you could stick with 0w20 for a while and change to slightly thicker in later miles. I would go ahead and start using 0w30 now if it was me.
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: jayjr1105] #5084694 04/24/19 10:32 AM
M
Matagonka Offline
M
Why did you go with AFE? Was it for fuel economy? Notice any difference?
2018 Mazda 3 Touring HB 2.5
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: Matagonka] #5084732 04/24/19 11:17 AM
J
J
(Thanks to this site.) I have a stockpile of 0w20. It will be a while before I consider a 0w30.
On sale at Costco that week. Since that OCI I've used Idemitsu 0w20, and my last change a week ago I used Supertech 0w20. Maybe it's placebo but the supertech seems to run really smooth. I will likely run it to 7K and do a UOA.
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: jayjr1105] #5084757 04/24/19 11:45 AM
dave123 Offline
SkyActive no fuel you have a winner with that amount of city driving I’d just stick with the M1 call it a day. I have 120K on my 2.0 Sky ran nothing but M1 since day 1 spotless looking and never a drop used.
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: dave123] #5084795 04/24/19 12:38 PM
J
J
Have you switched to 0w30 yet like some others recommend?
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: jayjr1105] #5084809 04/24/19 12:51 PM
JohnnyJohnson Online Content
Online Content
Silicon looks pretty good to me since your oils VOA comes with 6 ppm silicon.
2004 Corolla 136950
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76703
Out: T6 5W-40 XG9100 73705
In: Rotella Dino PH9100 11-3-19
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: jayjr1105] #5084902 04/24/19 02:23 PM
Char Baby Offline
I have noticed that in many UOAs that the TBN is missing. Is this an extra cost over & above the cost of the UOA?
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: Char Baby] #5084911 04/24/19 02:32 PM
J
J
Yes, extra $10 for Blackstone. I've seen UOA's from NAPA and other companies that include the TBN. Maybe those are extra fees as well.
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: Matagonka] #5085013 04/24/19 03:52 PM
O
O
Mobil1 Advanced Fuel Economy (AFE) 0w20 isn't anything special compared to other 0w20's available. Mobil falsely markets this. They always compare the 0w20 to a heavier viscosity, not fair. (There is about a 1% to 2% increase in fuel consumption from a 0w20 to a 5w30 from viscous drag in there alone.)
There IS a fuel economy advantage when using Eneos Racing Street 0w20 (SN) with a whopping 900 ppm moly FM and low kv40 too. Idemitsu Zepro 0w20 (SN) also high in moly, as is Mazda house-brand 0w20 (SN), both could give a small boost in MPG.
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: jayjr1105] #5085023 04/24/19 04:04 PM
dave123 Offline
No and no plans to and see absolutely no benefits nor would you.
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: jayjr1105] #5085459 04/25/19 12:42 AM
Char Baby Offline
Thanks.
"Retired"
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: dave123] #5085707 04/25/19 08:05 AM
O
O
Let's look at reality here. ...You can lower wear with slightly higher viscosity. This is via more hydrodynamic lubrication, less metal-to-metal inside.
Balancing cold startup flow with hot viscosity is important. Raising HTHS from 2.7 to 3.0 might help this Mazda meet or beat fleet average wear levels without harming cold startup.
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: oil_film_movies] #5085872 04/25/19 10:23 AM
B
buster Offline
B
I'm not sure I agree with you 100% here. AFE does have slightly different friction modfication than some of the other Mobil 1 oils (per Mobil engineer) and the ability to handle higher temps better than other 0w20's, as well as the best cold pumpability (MRV) of any 0w20 I've seen. It also has a Noack of 10%, which is better than many others that usually are over 12%. It's priced extremely well too.
I think EP 0w20/AP 0w20 are better at handling longer drains, but AFE is a good oil for its intended purpose. The fuel economy savings will be miniscule if any so I'm not even considering that into the equation.
A 0w30 will have a larger spread and therefore more VII's. I'd recommend a good 5w20. I have 60k on my 2.0 (2015) and I moved to regular M1 5w20. I haven't done any UOA's to compare though.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: 2013 Mazda 3 Mobil 1 AFE 0w20 6700Mi [Re: jayjr1105] #5144148 06/25/19 09:25 PM
Y
yamazy Offline
Y
which oil filter in this UOA?
