Schaeffer 204SAT and 205A
VA
Some of my cars call for Toyota T-IV and some Toyota WS.
Schaeffers 205A says it will work in both T-IV and WS transmissions.
Schaeffers 204SAT says it will work in T-IV only. It is "thicker" than the "WS".
Should I just use 205A for simplicity in all my Toyota transmissions or is it better to stick with the
204SAT in the older transmissions that specify T-IV?
I wish I new the actual specs required in all my Lexi and Toyota AT's. I was wondering if Aisin had them somewhere?
Doesn't your owner's manual have a JASO spec for your Aisin?
I would default to #205A if there is no other info.
I'll check.
I've been comparing the 40C and 100C specs among:
Maxlife ATF 29 (40C) and 6 (100C)
Mobil 3309 35 (40C) and 7.2 (100C)
Amsoil ATF 38.5 (40C) and 7.5 (100C)
Amsoil ATF (WS) 30.8 (40C) and 6.3 (100C)
Aisin ATF6 33 (40C) and 7 (100C)
Aisin AFT6 FE (WS) 30 (40C) and 6 (100C)
Schaeffer 204SAT 36 (40C) and 7.4 (100C)
Schaeffer 205A (WS) 31 (40C) and 6 (100C)
Toyota T-IV 34 (40C) and 7.3 (100C)
Toyota WS 23 (40C) and 5.5 (100C)
Yeah, I haven't had a lot to do after church today....LOL
Still looking for the non-synthetic Aisins specs.
Aisin T-IV 34 (40C) and 7.3 (100C)
Aisin WS 23 (40C) and 5.5 (100C)
Done for now.
Agree with the 205A for the later model, that's what I will be using in the 4Runner. Not sure about the earlier model but the 204SAT sounds right (without doing much research)
