Does the power plant pollute more when you plug in an electric car to charge?
Shannow, I'm genuinely curious.
Not sure on the question...but will use the Pelican Point example from above.
Pelican Point has a heat rate of 7.2MJ/KWh (it uses 7.2MJ per KWh that it generates.
A Hyundai Kona uses 13.6KWh to drive 100km...throw in 10% transmission and 10% charging losses - 16.5 KWh, or 118MJ of Natural gas to move the car 100KM. - $5.50 to drive 100km.
My wife's diesel Captiva uses 8.2L of diesel to move the car the same distance...35.86MJ/L, it uses 294MJ of fossil fuels. - $11.20 fuel costs per 100km.
However, when South Oz is using their OCGTs running diesel, not natural gas, heat rate is 11...180MJ of expensive diesel to do the same.
