I researched a bit more and......
Kinematic viscosity units conversion
1 cm^2/s = 100 cst
1 cm^2 = 100 mm^2
100 mm^2/s = 100 cst
1 mm^2 = 1 cst
AMSOIL Synthetic V-Twin Transmission Fluid (MVT)
Kinematic Viscosity @ 100°C, cSt (ASTM D445) . . . . . . 20.7 cst OR mm^2/S
Kinematic Viscosity @ 40°C, cSt (ASTM D445) . . . . . . . 190.3 cst OR mm^2/S
ViscosityIndex(ASTMD2270)............................................ 127
Scroll down to see the gear oil table on this site:
https://wiki.anton-paar.com/en/sae-viscosity-grades/
So the Amsoil stuff is in the xW110 range (high temp, summer) SAE gear oil viscosity grade.
(havent found a table for 40C gear oil viscosity)
Reply to ZeeOSix: That nomogram has a note that it applies only for VI 95 oils. The VI, I think, is related to the slope of the viscosity between 40c and 100c. So that fixes the relationship between the two scales on the left. The Amsoil product sheet says VI is 127. That may account for the the diff in my and your answers.
That said, yes the Amsoil is thinner than the HD, but 110 (Amsoil) vs 140 (Harley), at 100C.
I think I will pick up the HD product at next change and see if it provides a bit more cushion at gear changes.
I am NOT an expert on this stuff. Can someone who is validate my logic?
Anybody know where I can find a similar Gear oil table for 40C? Or a calculator or nomogram for VI 127?
