Originally Posted by Cdn17Sport6MT
Your Lexus, with dual injection, by virtue of the port injection (bathing the backs of the intake valves with semi-atomized gasoline - containing detergents) - would probably NOT have had any issues with carboning up the valves... Toyota / Lexus learned the hard way with the IS250 V6 (with low-tension piston rings and single- direct injection). That "cured" Toyota, from then on, re using single direct injection. Other credible mfr's, though, seem to be able to effectively run (solely) direct injection... with a fair amount of success...
The Mazda6 SkyActiv engines are (single) direct injected - and they seem to have a good track record. Similarly, Porsche? Likely others, too.
As for me, I think an effectively-engineered PCV flow filter system is worthwhile... Like a Mann-Hummel Provent 200, say. However, I think the hoses should be insulated well, and a minor, minor slipstream of engine coolant (heat tracing) should be run through, directly under the insulating covers. Also, pipe-sizes should be generous. The engine coolant heat tracing could be disabled when wintertime temps are high enough. I really have to worry about freezing-off the PCV flow... and then having the crankcase pressurize, blow out oil seals, etc... Much pain.
Yeah with the Lexus I didn't worry about carbon buildup on the valves, but oil consumption became a very real thing...and oil tracking into the intake.
As for the catch can in the winter, I never had an issue with the lines freezing...and I went through a two month stretch where temperatures were often below zero overnight, and driving to work that way (one hour commute). The contents in the can did freeze several times, but as for the lines? Didn't see anything. I think positioning of the lines is key - they must be positioned close enough to the engine to gather heat - and they must position in a way that pooling can't happen (a gathering of fluid). But for the most part it's only traces of oil and vapor in those lines heading up into that can, once it reaches the can, yes the contents will collect there and can freeze. So just empty it regularly so the can can't block flow. I never let mine go long enough where the level would raise that high. But as you know they can fill up pretty quickly in the winter due to condensation.
