Oil viscosities at 200 to 225 F
SE British Columbia, Canada
We just went through a forum discussion of measured oil temperatures. I think generally it was found that temps can get up to just short of 225 F and normal operating coolant temps in modern engines are around 200 to 210 F.
Does anyone have any data of the kinematic viscosities of oil at temps higher than the normal Kv100 ( 100 C or 212 F)?
I ask this because the Kinematic viscosity values flatten out once temps are at 212 F. I'm going to venture there is very little kinematic viscosity difference between an oil at 210 F vs 225 F. Can anyone offer up some data? Thanks.
Originally Posted by Snagglefoot
Originally Posted by OVERKILL
A visc calc should work properly at those temperatures, I'd just use that.
OK. Let's do one.
OK, what oil do you want to do? The example for a 5w-30 on Widman's site has the following characteristics:
40C: 62.5cSt
100C: 10.4cSt
105C: 9.4cSt
110C: 8.5cSt
115C: 7.7cSt
120C: 7.0cSt
125C: 6.5cSt
Unless the equations contain the exact coefficients of the specific VII, base oil used, and the additives used, don't count on this as being accurate.
That's good data. More of a change than I expected. Thanks.
Yep, enough change to undetstand why using a 30 or 40 weight oil at higher oil temperatures makes a difference in engine protection by providing a higher MOFT due to the higher viscosity.
For sure, I think it's sufficient for demonstrating the trend though. Same thing comes into play when folks try and extrapolate cold temp performance the same way.
I ran my Grand Cherokee through the mountains between 12,000 and 14,000 ft above sea level a few weeks ago, with my oil and water temps at 110ºC (230ºF) most of the day. No oil consumption on that 280 km trip (actually only down ⅛" in 8000 km). When it comes time to change oil, I'll send it in. But I run a PAO based 5W-30. Jeep started out with 5W-30 in 2011 and 2012, then changed their recommendation to 5W-20 for some reason.
Ambient temps were 15ºC (50ºF) most of the day, although I still get 108ºC on these drives when the ambient temp is below freezing, and snowing.
Also why I cringe when I hear about people taking their cars racing and thinking 300+°F oil temps are fine because their "oil can take it". The engine would be the better question to ask for sure.
I built and maintain a couple engines that use a dry sump oiling system. One of those engines is in a dirt Late Model that makes peak horsepower at 8300-8500 rpm and runs between 7500-9000 rpm for 100 laps or more. Even with an oil cooler, it's not uncommon for oil temps to reach 280+*F. We ran Valvoline VR1 20w-50 in it for a couple years until we started having oil pressure issues and eventually lost a dry sump pump. We put it on a dyno and ran it hard like it would be at the track and watched the oil closely. What we found was a lot of aeration, tons of bubbles in the oil tank, that increased with heat and rpm. We switched the engine over to Red Line 5w-50 and much of that aeration subsided, along with the average oil temp coming down about 10*F.
Despite all of that though, the guts all showed little wear when I tore it down after the pump failure.
The 3.6L runs hot, with those temps I'd be running 5W30 as well, which I do.
+1.
The general usefulness/applicability of Widman viscosity tool is beyond a doubt, even to an oil industry 'professional' if I may add.
I should have been more specific in stating that I was referring to OEM vehicles being run at the track with OEM street viscosity.
But yes, a properly built engine with a high HTHS oil can survive some noteworthy extremes.
Pretty interesting that VR1 wasn't holding up. Very unexpected.
Interesting note, last week I had to go over to the border with Brazil for a day, so ran the 400 miles each way at 100 mph (except in traffic and toll booths), with ambient temps of 94ºF and engine temps of 92ºC (198ºF). The transmission that runs 92ºC in the mountains ran at 74ºC.
A good read, thanks for sharing. Sometime interesting posts on here go unappreciated
