Quote
I don't believe there was ever voltage at the post on the fuse block until the key is in the first position
That can't be true, then you couldn't charge the battery from under the hood without key on and I did that.
Quote
Check/clean your terminals at the battery. Then find the main ground off the neg cable and clean that as well. I had a later 90's Cavy with the 2.4 which had piles of ground cable corrosion. Battery was testing good, had power to the interior but unable to turn the engine over. An old mechanic friend put me on the trail of the ground as he experienced this with many GM vehicles.
I'll do this but not confident that it's the latest problem. Something changed from one day having power at the post, me taking readings at the starter solenoid with multi-meter and the next day no power at post. When I was under the car with the meter and my son turned the key, there was a noise that did't seem to come from the starter but behind the starter. Where is the ECU on these things?
Quote
There won't be any fuses in the main cables between the battery, starter, and jump-starting post.
If this is true either the ground at the battery is bad or there is a short or break in the battery cable from the battery to the post on the fuse box.
