Originally Posted by Truckedup
Originally Posted by sunruh
Originally Posted by oil_film_movies
Lack of moly tells me this might work fine in a wet-clutch shared sump arrangement.
this shows you really don't understand moly
Explain......It appears to me, not a oil engineer, that most or all Jaso bike oils have little to no moly..?
There's Molybdenum in the Shell Rotella oils, the T4 15w40 CK-4 conventional has (4), the T5 15w40 syn-blend has (68), and T6 5w40 syn has (60), RedLine 5w40 syn has (570), and Valvoline 15w40 Max-Life has (63) moly
Edit: the Rotella T5 15w40 syn-blend does not show the JASO MA/MA2 on the label, the T4 15w40 and the T6 5w40 syn does show on the label, not sure if JASO shows on RedLine or Valvoline bottles
