So what is right and what is wrong?
A manufacturer that recommended mid grade or premium fuel, and an owner putting in regular. The system then protecting itself in the form of lower power.
or
A manufacturer that rates and designs its engine to run on 87 regular, but recommends premium for heavy towing or maximum performance. The system then taking advantage of higher quality fuel when it is used.
The latter is what my F150 with the 2.7 Ecoboost is. Its power numbers are based on 87 octane fuel. The Octane Adjustment Ratio (a measure of the octane used in engine adjustments) also reflects 87 as being the "norm" with the OAR generally hovering around zero (Range of -1 (Good) to 1 (Bad))
If I owned a vehicle that required premium, I'd likely fill it with that all the time. Mine does not, so I don't - unless I am towing heavy.
or
