Originally Posted by Truckedup
Ok...I've heard a few say they run Valvoline VR1 conventional oil in wet clutch bikes with no problems..I believe VR1 does contain the usual friction modifiers but perhaps the relatively high ZDDP additive cancels out the FM?
Probably true. Sometimes an oil is not strongly FMed-up. The VOA's on some VR1 oils I've seen show little or no moly FM. The organic friction modifier (OFM) "secret" content that doesn't show up on a VOA or UOA may be high, yet OFM might not interfere with wet clutches since it's not solid-particle plating metal surfaces. ................. Bottom line, the oil maker will tell you if its OK to use with wet clutches, or you can also try an oil to see if clutch operation is fine. People report some of the diesel engine oils can be used in wet-clutch motorcyles, and they have little or no FM. We usually see almost zero moly in diesel engine oil in a lot of cases,
VR1 is odd as a racing oil. Most racing oils have a lot of moly to lower oil temperatures, increase wheel HP, and reduce fuel consumption in a race.
When you see GF-5 (or GF-4), or "SN-RC" on an oil, it is FMed to pass the Sequence VID fuel economy test, and should definitely be avoided if you wanted to try it in a motorcyle. Of course any xw-40 or xw-50 oil isn't going to be GF-5 or SN-RC anyway.
