M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
74 registered members (ammolab, Aichiguy, 928, AndyB, AlaskaMike, 13 invisible), 1,541 guests, and 59 spiders.
Topics286,168
Posts4,903,484
Members67,572
Most Online2,967
Mar 10th, 2019
1998 V6 3800. Thermostat question #5044095
03/15/19 04:55 PM
03/15/19 04:55 PM
Illinois
Mark72 Offline OP
Mark72  Offline OP
Illinois
This car uses a factory 192 therm but I can also put a 180 in it. Would that hurt anything? This car runs at 210 and then when it's hot it goes up between redline and 210.
Re: 1998 V6 3800. Thermostat question [Re: Mark72] #5044114
03/15/19 05:07 PM
03/15/19 05:07 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
The engine and associated engine management was designed with a 192 stat in mind. Changing it to a different value will thrown things off. If your car is over heating, you have a different set of problems that should be addressed first.
Re: 1998 V6 3800. Thermostat question [Re: Mark72] #5044162
03/15/19 05:31 PM
03/15/19 05:31 PM
Martinsburg West Virginia
71Chevyguy Offline
71Chevyguy  Offline
I have actually experienced this and can comment from my experience. I read that it is better for the car to have the 180 degree thermostat in it, so I tried it in both of my 3800 cars. One is supercharged,the other one isn't. If you do go to a 180 thermostat, it has to be one that doesn't have the little relief hole in it to keep air out of the system. There would be enough of a bypass to set a check engine light if it had the bypass hole. As for how the car drove? Heat was fine, not usually an issue in these cars. No check engine light. Temp on the gauge was a bit lower but didn't really seem to affect anything. Tranny stayed cooler for sure, because mine acts up as it heats up and that was definitely better. If your car tends to ping occasionally, it did remedy that in mine. Overall it did drive a little better, not much but there was a difference. I would say it had more mid-range torque probably due to not pulling timing from higher engine temps. What was a deal breaker for me, was that it cost me about 5 mpg. So since I drive drive a lot, the oem thermostat went back into both cars and fuel economy went back up instantly. So it is up to you, if you are having issues keeping it cool in a very hot area, such as Florida, then it might be a good idea to switch, may not even lose fuel economy there. If your vehicle is overheating , then you need to fix the problem , not mask it with a thermostat. This is all assuming you have taken care of the intake gaskets and upper manifold issue if that hasn't already been done on your car. * Just noticed you are in Illinois, unless you constantly sit still in traffic, you probably are better off staying with the OEM temp. Down south is a different story.
18 Focus 1.0 Valvoline Modern Engine 0w20 / STP XL filter
99 VW Beetle TDI M1TDT / Mann filter
98 Buick LeSabre Kendall HM Ti 5w30 GF4 / Bosch Dist+
85 Skylark 2.5
71 Nova 250
Re: 1998 V6 3800. Thermostat question [Re: Mark72] #5044176
03/15/19 05:36 PM
03/15/19 05:36 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Its not going to make much difference one way or the other but I would make sure the electric fans are working properly. If one or both (IIRC this has 2) has failed the temps will increase no mater what the thermostat temp is.
Re: 1998 V6 3800. Thermostat question [Re: Mark72] #5044312
03/15/19 07:08 PM
03/15/19 07:08 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
The stat only controls the minimum temp. If you change it to a lower temp its still going to run the same temp once the stat is fully open.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
