M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
74 registered members (ammolab, Aichiguy, 928, AndyB, AlaskaMike, 13 invisible), 1,541 guests, and 59 spiders.
Topics286,168
Posts4,903,484
Members67,572
Most Online2,967
Mar 10th, 2019
Honda pioneer 1000 #5041017
03/12/19 08:45 PM
03/12/19 08:45 PM
Pennsylvania
Mahanoy Offline OP
Mahanoy  Offline OP
Pennsylvania
Hello. I just bought a 2018 Honda pioneer 1000 and I am soon ready to change the oil. The manual says to use 10w30 or 10w40 if it does not get below -10 degrees f. I am thinking of using Lucas 10w40 atv/utv motor oil suitable for wet clutches since this utv has clutch packs. The manual says to use an oil that meets spec JASO MA. The Lucas meets JASO MA2. Is there a difference between the specs? From what I read it should be fine to use. Also I am going to be changing the gear oils. Not sure but I think it's just a 80w90 weight gear oil. I have either castrol 75w140 or 75w90 in a 30 gal drum. Will they also work? Thanks, Mahanoy
Re: Honda pioneer 1000 [Re: Mahanoy] #5041065
03/12/19 09:33 PM
03/12/19 09:33 PM
Arkansastan
Propflux01 Online crying
Propflux01  Online Crying
Arkansastan
Yes, you can use either flavor of the Lucas, if that is the oil you choose. Do not use the gear lube you have in the drum. It does not belong in your 1000 Any JASO MA1 or 2 will suffice.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: Honda pioneer 1000 [Re: Propflux01] #5041074
03/12/19 09:37 PM
03/12/19 09:37 PM
Pennsylvania
Mahanoy Offline OP
Mahanoy  Offline OP
Pennsylvania
Do you know what I need for the differentials on the pioneer? They seem to whine alot. I dont know if its them or the transmission
Re: Honda pioneer 1000 [Re: Mahanoy] #5041108
03/12/19 10:12 PM
03/12/19 10:12 PM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
A quick search found this for the 2016 model...not sure how much difference there is vs your 2018.
https://hondasxs.com/threads/differential-oil-change-front-rear-honda-pioneer-1000.4634/
Sounds like your 75W90 should work fine.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Honda pioneer 1000 [Re: Mahanoy] #5041306
03/13/19 07:42 AM
03/13/19 07:42 AM
wv
krismoriah72 Offline
wv
My buddy has one.. The Valvoline 4T 10w40 for $5.99/qt at Oreillys is what he uses.
https://www.oreillyauto.com/detail/...lvoline-motor-oil/atv1040/4773318?pos=29
