So on my recently acquired Accord, at least from PO oil history is good. But for initial years, I have no clue.
So essentially I have no history for first few years, except whatever is showing up on Carfax report which is not much.
I have already done PS fluid, coolant, ATF(single drain and fill), brake fluid(fluid change from reservoir).
Have not replaced engine oil(5W20) yet, because it has some miles and life left based on OLM and oil change sticker. Is there anything I can do on engine? Like using fully synthetic(or blend or conventional) with short interval or seafoam or MMO or anything along those lines?
I have quite a few sorts of oils in my stash, including Royal purple, Valvoline platinum, magnatec, castrol edge, rotella synthetic, etc...
Thanks for the help and advise
