I just bought a new Yamaha F25 (25 hp) outboard less than a week ago. The motor came from my dealer with Yamalube M4 10w30 oil that I will use to break the motor in on. After 20 hours of use, it is recommended that the oil and filter be changed per the manufacturer. I will more than likely change the oil and filter somewhere between 10 and 15 hours based on how dirty it looks. My question is...should I continue with the Yamalube plain M4 10w30 oil or go with the Yamalube synthetic M4 5w30 oil. Does anyone have any experience with the synthetic in this or a similiar model motor? Is there any problems with the synthetic causing any problems with the seating of the rings or in causing the motor to make oil? I know that four cycle outboards can be prone to not seating the rings properly and/or making oil, but I wasn't sure if the use of a synthetic vs. plain oil had any effects on this. Thanks for any comments back.
