Interesting test comparing wear differences using 5W20 Conventional vs 5W20 Synthetic.
https://www.chevyhardcore.com/tech-...gs-a-test-of-bearing-and-oil-wear-rates/
There is a couple of things that are "off", like the wear rates for Lead on the uncoated bearing + synthetic test, on the first chart (i think it should be the corect one) are 10ppm vs 23ppm on the second chart, it was also mentioned and changed the total metal count on both charts. The amount of zinc and phosphorus was also different on the same test compared to the other 3 that were the same.
