Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
66 registered members (Best F100, 69Torino, Billbert, bismic1, Astro_Guy, 9 invisible), 803 guests, and 51 spiders.
Topics284,589
Posts4,872,998
Members67,294
Most Online2,548
Feb 16th, 2019
2008 Ford Crown Vic P0152 Code #5006049
02/09/19 06:22 PM
02/09/19 06:22 PM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
Just picked up this car, it has a code for a bad O2 sensor (b2s1) but the sensor seems fine as per the data on the scantool?
Any suggestions appreciated.
[Linked Image]
[Linked Image]
PS: I also have a P1233 code, which I have to troubleshoot after, but one thing at a time I guess since they seem like two unrelated things.
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30
Re: 2008 Ford Crown Vic P0152 Code [Re: dogememe] #5006063
02/09/19 06:36 PM
02/09/19 06:36 PM
Columbus, Ohio
John_K Offline
John_K  Offline
Columbus, Ohio
Our 09 Grand Marquis throws that code about once a year. Then it stops. I ignore it.
2009 Mercury Grand Marquis, 8 cyl auto, 83xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 96xxx miles, Maxlife/OEM Filter
Current oil stash: 518 qts.
Re: 2008 Ford Crown Vic P0152 Code [Re: John_K] #5006075
02/09/19 06:45 PM
02/09/19 06:45 PM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
I can't ignore it, unfortunately. Code = fail smog = no registration.
Re: 2008 Ford Crown Vic P0152 Code [Re: dogememe] #5006092
02/09/19 06:57 PM
02/09/19 06:57 PM
MN
14Accent Offline
14Accent  Offline
MN
My Marauder threw the same code. My data looked just like yours, but the PCM didn't like it. A Motorcraft sensor is around $45, just replace it.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: 2008 Ford Crown Vic P0152 Code [Re: dogememe] #5006228
02/09/19 08:42 PM
02/09/19 08:42 PM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
Ok, thanks all, will replace it tomorrow. It looks like this one is easy to get to from above, it's right next to the steering shaft (which was recently replaced, hmm...) Just not sure how to get to the connector. Guess I'll figure that out once I yank it out. I hate Bosch O2 sensors but that's what I'm going to be installing since Denso and Motorcraft are special order for this applies.
Re: 2008 Ford Crown Vic P0152 Code [Re: dogememe] #5006376
02/10/19 12:13 AM
02/10/19 12:13 AM
Kuwait
Falcon_LS Offline
Falcon_LS  Offline
Kuwait
Yeah, they won't let it pass smog with that code.
Go ahead and replace both sensors, since one started acting up, the other one won't be too far behind.
The OE sensor is NTK, I'm actually running Bosch, which has been my go-to, never had any problems. The connectors are a bit of a pain in the back to get to, and a bit of a reach.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
03 Expedition SSV: XG2
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: 2008 Ford Crown Vic P0152 Code [Re: dogememe] #5006730
02/10/19 11:11 AM
02/10/19 11:11 AM
MN
14Accent Offline
14Accent  Offline
MN
The connector was tough on mine too, but at least with a SOHC you can get to the sensor. The heads on the DOHC 4.6 are so wide that I had to do it from below.
Re: 2008 Ford Crown Vic P0152 Code [Re: 14Accent] #5006810
02/10/19 12:37 PM
02/10/19 12:37 PM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
I hope I can do it from above? Going to try to change it on my lunch break!
Re: 2008 Ford Crown Vic P0152 Code [Re: 14Accent] #5007002
02/10/19 02:58 PM
02/10/19 02:58 PM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
Ok, I unscrewed the old sensor and installed the new one. Can I unplug the old one and plug the new one in without getting underneath the car?
Re: 2008 Ford Crown Vic P0152 Code [Re: dogememe] #5007174
02/10/19 05:16 PM
02/10/19 05:16 PM
MN
14Accent Offline
14Accent  Offline
MN
I can't remember exactly where the connector is but I remember having a hard time disconnecting and reconnecting. Follow the wire back and find the connector.
Re: 2008 Ford Crown Vic P0152 Code [Re: 14Accent] #5007179
02/10/19 05:20 PM
02/10/19 05:20 PM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
Yeah, I found the connector, and by pulling the old (still connected) O2 sensor upwards I can almost get to it, but it's just a little too deep between the engine and firewall to get to it. I feel like this should be easy but I'm missing something obvious. I'm trying to avoid getting underneath the car.
Re: 2008 Ford Crown Vic P0152 Code [Re: dogememe] #5008310
02/11/19 07:22 PM
02/11/19 07:22 PM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
Well, sometimes I try too hard to be lazy. I drove the car onto ramps and had it all done in about 30 seconds. Getting to the connector from underneath was ez-pz.
Moderated by  ekpolk
