Originally Posted by eddy21
Originally Posted by dailydriver
Since Ford does
NOT have any currently approved, or warranty friendly methods of cleaning the intake valves on their TGDI engines (save for replacing the WHOLE head assembly!
), I must do every little thing possible, even if it seems 'futile', to keep those deposits out of the intake.
(I already use ONLY top tier fuel, Shell V-Power with
occasional dosing of Red Line SI-1, will change out the plugs every 15K miles, and use ONLY D1G2 oils.)
Wow, that's a lot of additional ongoing maintenance activity.
Do others report similar requirements?
Does Ford acknowledge this level of additional requirements??
(V-power fuel, 15k sparkplugs, Redline, etc...)
Ford does not "acknowledge" anything, but they also do not "acknowledge" any solution for any IVD problems either, save for replacement of the WHOLE head as an assembly.
FINE if one is still under warranty, NOT so nice if not. (So YES, if it needed cleaning
after the power train warranty was up, I would go the walnut shell blasting procedure for ~ $400 instead.)
I would rather avoid any problems altogether, so if a bit of extra maintenance is the cost, I do not mind one bit (I LIKE working on this car, unlike most U.S. consumers who will never even check their own oil, IF they even can with a dipstick anymore, LOL).
I use premium fuel ANYWAY (to get the most performance out of this engine, since Ford's OAR system in the ECM WILL increase timing per sensed octane, and therefore more power/response), the plugs are VERY EASY to change out, and not that costly, even for NGK Laser Iridiums, the OCC is VERY easy to drain, and the Red Line additive is reasonable if bought from an online seller during a sale.
There's a guy in the Titusville area that does walnut blasting for $250 , Long drive for you . He's Jay Heath on Fiesta Facebook page . For the record before CC I had oil in my intercooler and hot side hoses, with none whatsoever .
IF you are speaking of Titusville,
N.J. (??), that is about 15 minutes
with traffic from where I am, so that is good to know (and a ****uva lot closer, AND less coin for the procedure) than going all the way down to Custom Performance Engineering in Spartanburg, S.C. to have ST specialist Mitch there do the WSB cleaning!
Yes, the cleaner hot side ducting is also another benefit, and given that these engines CAN use
all of the octane they get, I figure that keeping any octane reducing oil in ANY form
at all; mist, droplets, whatever, etc.
OUT of the combustion mixture, is a GOOD thing, even if the can does not do much for the dreaded IVD issues.
