Oil filters on Mopars don't bark, chirp, or tweet, even with GM snowflakes melting all around them.
Originally Posted by Triple_Se7en
Originally Posted by ofelas
Coldest I saw this winter was -30c.
Couldn't make out the difference between my current 0w40 fill and the previous 5w30 HDD fill - I tend to check by how quickly the dash oil pressure gauge needle rises, as I'm too lazy to open the hood & watch the mechanical gauge while someone else cranks the truck.
Surprisingly, I've never had a noisy/sluggish winter steering issue, though I only use the obsolete MS-5931 PS fluid. Still have a few 12-pack cases of OEM fluid left.
You can't hear the difference between 5w30 and 0w40, , unless you are standing in front of the radiator when the engine is started by someone else.
You may even hear a barking oil filter then too.
