98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
patman3d, Oillogger, Rob707, rageyourdreams, Beemer25
68692 Registered Users
22 registered members (clinebarger, Bailes1992, Chesterr, Bjornviken, doolah02, Dylan1303, 2 invisible), 729 guests, and 21 spiders.
Topics292,010
Posts5,015,196
Members68,692
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Tire Pressure Dash Light Is Irritating Me [Re: Gebo] #5001309
02/04/19 02:58 PM
02/04/19 02:58 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Sorry if I missed it, but does the vehicle show tire pressures or just the lights?
Like EdwardC said above, there's typically the two separate indicator lights. The one you have (tire cross section with !) and the TPMS light which typically lights when the system itself is having problems with either the transponders in the tires or the receiver(s) on the vehicle.
I too would try airing the tires up to closer to 40psig and see if the light goes out. Like said, the TPMS have a +/- 3psig or so deadband you have to clear for the warning to clear.
2017 Ram 1500 4x4, 3.6L.
2016 Nissan Quest SV (Babe magnet IV)
2015 Nissan Versa 1.6 S
Re: Tire Pressure Dash Light Is Irritating Me [Re: Gebo] #5001328
02/04/19 03:13 PM
02/04/19 03:13 PM
WY
sloinker Offline
sloinker  Offline
WY
I despise in the tire TPMS sensors. I heartily approve of the style VW and others use that measures a couple different parameters to determine if you have a low tire. Easily reset-able through the on board menu.
Re: Tire Pressure Dash Light Is Irritating Me [Re: Gebo] #5001519
02/04/19 07:33 PM
02/04/19 07:33 PM
ME
eljefino Offline
eljefino  Offline
ME
You're lucky in that it's a toyota product for which you can get an economical Techstream dongle on ebay which gets you diagnostic abilities.
Do you have a button for it under the dash? This sets the "now" PSI and the light will only come on at 20% under this.
Techstream reads for me, and maybe for you, if the sensors have low batteries. Since you bought new recently, this is unlikely but not impossible.
You'll notice I have one bad/missing sensor giving no data, and a couple with low batteries:
Re: Tire Pressure Dash Light Is Irritating Me [Re: Gebo] #5001587
02/04/19 09:13 PM
02/04/19 09:13 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I put a piece of black tape over my tire pressure light.
Nothing I ever did would stop it from coming on.
Re: Tire Pressure Dash Light Is Irritating Me [Re: Gebo] #5001607
02/04/19 09:50 PM
02/04/19 09:50 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Originally Posted by Gebo
Originally Posted by EdwardC
In my experience, there's usually two TPMS indicator lights, one is the tire cross section with the exclamation point, the other has the letters "TPMS". The first indicates that it detected a low tire pressure, the second that there's an issue with TPMS system itself (as if the receivers aren't getting data).
I don't know for sure, but it seems reasonable to me that maybe due to the temperature fluctuations, it could sense a fairly rapid decrease in pressure, and it is throwing a warning due to that.
This light is of the cross section of the tire with the exclamation point.
I think I'll reread the owner's manual.
I had that same light on my Honda when my then-12 year old TPMS batteries started dying. I bought 4 new Schraders on Amazon for $35/ea and when I bought new tires, had the tire shop replace all of them. Still had the light after that. Bounced tires, one had a rattle. Tire shop broke one of the Amazon TPMS sensors, they put on a new one for free, but had already warned me they couldn't program any of them. (Honda Pilot is supposed to be self-syncing.)
I tried the deflation test, and got only two low pressure indicators on one side, none on the other. The Low Pressure indicator was a different indicator than the one your describe, showing me which tire(s) was low.
After almost a year of futzing around with wheel rotations, resetting the TPMS computer, etc., I took it to my trusted local mechanic and for a little over $120 he replaced the two bad sensors on one side, programmed them and gave me back the broken ones. It was crazy how fast he diagnosed and fixed it.
I returned the broken ones on Amazon and got my $70 back, almost a year later.
So in the end I still saved money, but next time I know who I'm going straight to for new TPMS sensor installation and programming.
Various musings: http://hangfire.net
Re: Tire Pressure Dash Light Is Irritating Me [Re: Gebo] #5001636
02/04/19 10:36 PM
02/04/19 10:36 PM
Cloquet Mn.
bobbobtar Offline
bobbobtar  Offline
Cloquet Mn.
I had a bad tire pressure gauge off by 5-7 psi. I was running my tires at 35 psi and the light would trip at 27 psi and the temp overnight could change by 40 degrees finally figured by using a higher psi.
2017 Toyota Highlander
2018 John Deere 2032R
2014 CanAm Spyder
1981 Chevy Malibu 355cu 425hp
Re: Tire Pressure Dash Light Is Irritating Me [Re: Gebo] #5001655
02/04/19 11:09 PM
02/04/19 11:09 PM
5600 feet elevation, Arizona
double vanos Offline
“Electrical tape”.
And right back to the 60’s when a driver checked his tire pressures weekly. I miss those simpler days...
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Tire Pressure Dash Light Is Irritating Me [Re: Gebo] #5002078
02/05/19 02:54 PM
02/05/19 02:54 PM
WI.
dblshock Offline
dblshock  Offline
WI.
I disabled the T4R TPMS found the trick on You Tube.
05 Lexus GX470 167k
640:1 TCW-3
5/30 10/30 5/40 15/40
Michelin Latitude
06 4Runner SR5 150k
640:1 TCW-3
Citgo 10/30 conv XG3614
Falken Wildpeak AT3W
Re: Tire Pressure Dash Light Is Irritating Me [Re: Driz] #5002417
02/05/19 08:52 PM
02/05/19 08:52 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
Originally Posted by Driz
Originally Posted by CT8
Electrical tape
Sometimes the simplest ideas really are the best🤗. Those things are nothing but a menace !
Until you get a nail in a tire during a long highway ride and it warns you before the tire goes completely flat or you roll over on a sharp curve.
Re: Tire Pressure Dash Light Is Irritating Me [Re: atikovi] #5002740
02/06/19 09:10 AM
02/06/19 09:10 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
Electrical tape
Got my first TPMS vehicle 38 years after getting my driver's license, 37 years after getting my first car...
How did we ever survive without TPMS?
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Tire Pressure Dash Light Is Irritating Me [Re: Gebo] #5002881
02/06/19 11:13 AM
02/06/19 11:13 AM
California
DGXR Offline
DGXR  Offline
California
My Toyota TPMS measures change in pressure, so the system will trigger when the pressure gets significantly higher or lower than the "set" pressure. It's 12 years old and the tire sensors recently died, so I had them replaced (spare tire takes a different sensor than the main 4 wheels, GAH!) This is how I learned of the system behavior: a steady dash light indicates a pressure issue, a flashing dash light indicates a system malfunction. Toyota standards of behavior may have changed since 2006.
Get a known good gauge and set all 5 to the factory pressures on the door jamb, or whatever you normally run. Be consistent. Then reset the system and you should be good. I check my pressures monthly and never had any issues besides the batteries aging out, mentioned above.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Tire Pressure Dash Light Is Irritating Me [Re: Astro14] #5005516
02/09/19 08:25 AM
02/09/19 08:25 AM
atikovi Offline
atikovi  Offline
Electrical tape
Not EVERYBODY survived. Ask the people in Explorers that rolled over from under inflated tires. Oops, you can't, they are dead. Anyway, you could also argue, how did we ever survive without safety glass, seat belts, airbags, navigation, etc.
Page 2 of 2 1 2
