Your is first gen or second gen dsm ?
way before I move to american car, I own 3 dsm, 2 second gen and 1 first gen. 4G63 engine love 10w30 oil. STICK WITH 10W30 OIL WEIGHT AND NOTHING ELSE !
For your tranmission if it 5 speed, use 1 quart of redline shock proof gear oil and the rest is pennzoil syncromesh this is home made mix recomment by best tranmission builder john shepherd
or run Red Line Manual Transmission Lube MTL (Transmission)
Red Line Heavy weight Shock Proof Gear gear oil for X-fer case, rear diff ( if your is AWD version )
NGK plug ONLY and mitsubishi spark plug wire, I use to change plug every oil change. its very easy, 4 plug, and everything is coming from the top.
Get greddy turbo timming, and set it for 1 min after turn off the key, so the car still running 1 min after u take the key off
UNPLUG CLUTCH STARTER SWITCH IF YOU A SECOND GEN DSM ! start the car without using clutch to prevent crank walk ^^
check for boost leak every oil change, their a home made tool you can build at home depot for 10 dollar to check for boost leak.
DO NOT CHANGE OIL EVERY 5K+ CHANGE IT OFTEN ON THESE ENGINE, 4G63 is not like any other engine, I do not want get bash for recomment u change oil early as 3k miles, but I know it from owning these engine for few year, go to the forum below and speak with the peoples that know about these type of car, its require alot maintaince. Say Killa send you.
Go to this forum, I learn everything from that forum, many peoples are move on to different car now, but still have many still stay with dsm no matter how much money pit its. I still miss mind alot
I learn how to take care car and keep maintaince it because of the dsm, cause dsm need ALOT attention and maintaince.
http://www.automotiveforums.com/vbulletin/forumdisplay.php?f=343
