Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
54 registered members (Astro_Guy, alarmguy, 69Torino, AndyB, Aero540T, 2015_PSD, 5 invisible), 681 guests, and 49 spiders.
Topics284,589
Posts4,872,986
Members67,294
Most Online2,548
Feb 16th, 2019
Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost #5000120
02/03/19 08:46 AM
02/03/19 08:46 AM
IL
jcartwright99 Offline OP
IL
I have had this car for a 1.5 years, only had Motorcraft (both FS/SB) and Castrol Magnatec 5w-30 in it. I used the Dexos 1 generation 1 formulation of the Castrol with fram ultra oil filter. I will be making the switch to Dexos 1 Gen 2 next oil change. This is my second UOA with the Castrol. My driving would be classified as severe based on the amount of stop and go in the Chicago area. I did have 2 400 mile trips to Michigan on this as well.
I am pretty impressed with the Magnatec. For the cost, it seems to do well with my engine. I've decide to go with 7k OCI's and keeping on using Castrol.
Attached PDF document
OilReports- npd.pdf (106 downloads)
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5000136
02/03/19 09:06 AM
02/03/19 09:06 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Awesome results. Only 1.3 ppm iron per 1,000 miles. And that is with less than a 9 cst kinematic viscosity. smile
If you want the job done right......do it yourself.
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5000152
02/03/19 09:20 AM
02/03/19 09:20 AM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
Looks real good for a turbo DI 7,000 mile run. Your Ecoboost does the same as our 2.3, it shears the oil a bit and lowers the flash point as well as showing a trace of fuel dilution. This definitely did NOT effect the wear metals. Also that Magnatec looks like it meets the Dexos 1 Gen 2 standards with the lower calcium and higher magnesium levels, even if the jug didn't say so.
Whimsey
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5000188
02/03/19 09:58 AM
02/03/19 09:58 AM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
Nice Report,
Thanks for Posting. thumbsup
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive236K miles
PPHM 5w30 x 2 Fram Ultra x 2
Currently under the influence of oil shocked2
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5000198
02/03/19 10:15 AM
02/03/19 10:15 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Good idea not to extend the next OCI with this brand-model oil. I've looked at a few UOA/VOAs of the D1/G2 SN Plus version of Magnatec and it shows slightly weaker addpack, than your shown (presumably SN) version.
This is an ideal Magnatec pairing for your engine. But so would be Mobil-1, Pennzoil Platinum, QS Ultimate Durability, Castrol Edge and Valvoline Advanced, which Valvoline now shows a pretty stout add-pack (as shown in a new VOA I read yesterday.
I moved away from Valvoline recently, reason-being is their Maxlife synthetic product I tried. But the Advanced Synthetic looks promising..... however the unknown being is what's being used now as their base oil. That may have changed also.
2019 Hyundai SantaFe 2.4 factory fill / QS 5w20 conv. / Mahle OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5000350
02/03/19 12:28 PM
02/03/19 12:28 PM
MN
oil_film_movies Offline
MN
This does look like a dexos1 Gen2, as noted above, with the high Mg an low-ish Ca. Titanium is a nice addition, similar to Castrol, Kendall, & Valvoline using it. This did shear & fuel dilute down to effectively a 0w20 or 5w20, yet for most of the oil change interval is probably was a light 30 weight anyway. It has tolerance for lowered visc.
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5000485
02/03/19 03:03 PM
02/03/19 03:03 PM
Maricopa, Arizona
dave1251 Offline
dave1251  Offline
Maricopa, Arizona
You can just follow your iOLM it is accurate for this engine and lube combo.
don't use.
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5000789
02/03/19 09:10 PM
02/03/19 09:10 PM
Cascadia
BikeWhisperer Offline
Cascadia
Looks great, the Dex 1, Gen 2 Magnatec is going in my wife's Edge with the same engine as well as my F150 with the 2.7 Ecoboost on the next oil changes.
2015 F150 XLT SCrew 2.7 Eco-Boost
5w-30 Motorcraft Semi-Syn, FL2062
2018 Ford Edge SEL Eco-Boost 2.0
5w-30 Motorcraft Semi-Syn, FL-910S
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5000898
02/04/19 01:51 AM
02/04/19 01:51 AM
Samara, Russia
Gubkin Offline
Gubkin  Offline
Samara, Russia
Can you provide a photo of canister please ?
looks like Castrol Magnatec Professional DX 5W-30 (SN, GF-5, dexos1 gen2)
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: Gubkin] #5001030
02/04/19 08:42 AM
02/04/19 08:42 AM
IL
IL
No, it’s long gone. I can tell you the 5 qt. jug only mentioned dexos 1( no mention of gen 2). Same with the additional qt. Next change I’ll take a photo and keep for my records.
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5004834
02/08/19 11:42 AM
02/08/19 11:42 AM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
Ford recommend magnatec in EU
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5005038
02/08/19 03:24 PM
02/08/19 03:24 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
^^^NO surprise, since Castrol sponsors all of their Euro rallying/racing endeavors there. wink
2016 Ford Fiesta ST 14K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Castrol Magnatec 5w-30, 6924 miles- 17 Ford Fusion 2.0 Ecoboost [Re: jcartwright99] #5008214
02/11/19 05:23 PM
02/11/19 05:23 PM
5600 feet elevation, Arizona
double vanos Offline
Nice report.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Moderated by  ekpolk
