Pilenga Rotors - Made in Italy?
by The Critic - 11/17/19 01:34 AM
More Dog pics
by Marco620 - 11/16/19 11:48 PM
which weather site is most accurate?
by WhyMe - 11/16/19 11:25 PM
mopar coolant
by boombie10000 - 11/16/19 11:11 PM
2015 Honda CR-V loud engine noise
by FordBroncoVWJeta - 11/16/19 11:10 PM
Old Vise info
by A310 - 11/16/19 10:18 PM
2003 Ranger Radiator Replacement: Which Coolant?
by chucky2 - 11/16/19 08:55 PM
ATV axle removal
by supton - 11/16/19 07:45 PM
High speed chase
by P10crew - 11/16/19 07:28 PM
Oil for Daily Beater Camry
by Speak2Mountain - 11/16/19 07:18 PM
Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
billad67, Diverdown, natas, matt3540, ChrisWild
69886 Registered Users
21 registered members (Duffyjr, bmod305, czbrian, bbhero, ctechbob, 2 invisible), 826 guests, and 22 spiders.
Topics297,525
Posts5,117,402
Members69,886
Most Online3,589
Nov 2nd, 2019
Page 3 of 3 1 2 3
Re: more PSD woes with cold weather [Re: fdcg27] #4991757 01/26/19 06:30 PM
G
Garak Offline
G
Originally Posted by fdcg27
Our old fully mechanical Mercedes 240Ds were never a problem in cold weather, if you could get them started.
Back in the day here, people were fond of plumbing in some inline coolant circulating heaters to various Benz diesel models to the point they began to enclose some Mercedes specific instructions in the packaging. wink
Donald: The tip that always works best for diesels is fill up where the truckers fill up. That way, you know you're getting fresh fuel and fuel that probably isn't going to debilitate the vehicle, aside from the rare cases when a storage tank is incorrectly filled.
Plain, simple Garak.
Re: more PSD woes with cold weather [Re: Donald] #4995326 01/30/19 06:01 AM
Donald Offline OP
I have been emailing the fuel companies and asking how low a temperature will their fuel still be usable. Shell has said -18C at least in the Albany NY / Western MA area.
A local fuel oil company owner said the diesel he buys for his own trucks has gelled invrecent cold weather and he has dumped in extra kerosene.
But for an individual, the kerosene available available (for kerosene heaters) is dyed heating fuel and not taxed.
2015 Ford F250 w/Powerstroke
Re: more PSD woes with cold weather [Re: Donald] #4995352 01/30/19 06:32 AM
dnewton3 Offline
Global Moderator
Global Moderator
I have used Power Service White Bottle successfully for decades; started using it back in 1986 with my first diesel car (Tempo). I have used it my my tractors for years. I have had no issues with it down to -17F in my Dmax and my Kubota. I suspect it's NOT a problem with the additive IF the fuel is a proper winter blend. However, if the fuel is not properly blended, it may ultimately affect the ability of the additive to do it's job. When it was -17F a few years ago here (real temp, not windchill), not only did my Dmax (common rail) and Kubota (mech injection) both start, but they did so with no hesitations or stumbles, and after a gentle warm up for a few minutes, drove away just fine with no fuel issues. So if your fuel is a proper winter blend, and you've added the right amount of PS WB, then I cannot expect it's the additive. But if the fuel is NOT the right blend, it's cause for concern.
Regarding the red bottle 911 from Power Service, I don't think it would hurt, but I'd call them and ask. And specifically, I believe 911 is essentially a product to give relief of fuel that is frozen due to moisture being in the fuel; the alcohol relieves the frozen water crystals. But, if the fuel is not blended correctly for a winter application, I'm not sure that the 911 will address this. I am not 100% sure of this; that's why I suggest calling them and asking prior to adding it. But it seems to me I had this conversation with them several years ago; I had called them with a question about their biocide and got into a side topic conversation about the 911 product. They have a very helpful tech-line group; or at least they did a while back. When reviewing their website info for the 911 product, it clearly states that it's safe to use and will not void OEM warranties if used as directed. Ford has a statement to not use alcohol based products. So there's a bit of a disconnect between them. I would defer to the PowerSerivce folks for detailed info. The PS 911 product states it will re-liquefy gelled fuel, but it also states it will not prevent fuel from gelling. Not sure why there's a distinction there.
From Ford's perspective, you might even call your Ford dealer and ask them what to use; maybe they have a recommended product? "Alcohol", as we know, is a very large and broad term. There are many different kinds of alcohol. Perhaps the Ford statement is just a catch-all warning because going into the weeds in an owner's manual would be too much to digest, and given their nearly schizophrenic approach to additives and lubes .....( ala don't use CK-4, but you can use anything on our approved list, which includes a bunch of CK-4 lubes )... I am not sure they'd be able to give you a detailed answer anyway. MAYBE there are products that use alcohol that are much less harmful, or OK to use only in extreme circumstances. And this is why I'd defer to the PS folks and shy away from Ford's advice, as they have a habit of throwing out blanket statements and then not only violating their own advice, but being mum as to why/how they make these decisions in the first place.
i would call PS and speak to them again, giving them all the details and concerns, and ask about what product(s) to use.
The other things to mention are checking the install of the filters from the recent changes.
Also try to get some fuel from a high-volume source that has winter blends; as suggested from others maybe a truck stop that's not too far away?
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: more PSD woes with cold weather [Re: Donald] #4995391 01/30/19 07:19 AM
I
itguy08 Offline
I
Can you check other places for Kerosene? Last time (a year or so ago) I bought Kerosene from the convenience store pump it was crystal clear. That was in PA though so it may be different up in NY. Would one of those gallon jug of Kerosene from Home Depot or Lowes work? They are pricey but you may not need much to get that bad tank of Diesel out.
Re: more PSD woes with cold weather [Re: Donald] #4995546 01/30/19 10:19 AM
M
MNgopher Offline
M
Where do the medium and heavy duty trucks fill up in your area? Any decent, high volume diesel retailers in the area (truck stops for example?) In the winter, try to buy diesel there - better odds of getting properly winterized diesel and not a bunch of older stuff in th tank.
Re: more PSD woes with cold weather [Re: Donald] #4995627 01/30/19 11:32 AM
supton Offline
K2 for heaters would be pricey but should be crystal clear. But, for me, I'd be leery of putting in K2 into a modern diesel, fears of (lost) lubricity would be dancing in my head.
2011 Toyota Camry, base, 2.5L/6MT, 194k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 215k, his
Re: more PSD woes with cold weather [Re: supton] #4996033 01/30/19 05:53 PM
Donald Offline OP
All winter diesel is blended with kerosene. Stewart's Shop said they are using 20% kerosene.
Re: more PSD woes with cold weather [Re: Donald] #4999518 02/02/19 01:27 PM
Donald Offline OP
So I was told I should be asking what the CFPP is (cold filter plug point) is rather that just " how could a temp can I use your diesel fuel at"?
Pride Stations in Western MA says -16F
Re: more PSD woes with cold weather [Re: Donald] #4999526 02/02/19 01:35 PM
R
roadrunner1 Offline
R
We were at -18F here a couple days ago and I had to unexpectantly run my 6.7, so no block heater was plugged in. No fuel or starting issues here in NW OH.
My youngest son had ignored advise to leave his water drip and had frozen water line in crawl space.
If you're running Motor Craft filters then your fuel supply is suspect.
'15 F350 6.7
Re: more PSD woes with cold weather [Re: roadrunner1] #4999787 02/02/19 07:02 PM
Donald Offline OP
Letting water drip can help or make things worse. If part of the sewer pipe is exposed to freezing weather as it might be in a drawl space letting water drip can cause ice to form and eventually block the sewer line. I left a large chunk of ice in my kitchen sink where the sewer line is exposed to freezing in the crawl space before going underground. The drip drip drip of the ice melting caused the sewer line to freeze with ice. A real PIA.
Re: more PSD woes with cold weather [Re: Donald] #5000299 02/03/19 11:37 AM
B
BrianF Offline
B
Just because a company or supplier states their winter blend is good to a certain temp does not mean the station is using that fuel. They may have some odd mix of fuel in the tanks and unless you test it, how do you truly know? I can only reiterate what others have said: Get your fuel from large stations with high turnover. Go where the truckers go. Unless the owner is a good friend and can truthfully tell you what type of fuel is in their tank.
I go to high turnover stations and have yet to run into a problem. I go to the same stations where my friends have gone for years with their diesels and have yet to run into issues. Very few people I know that run diesels up here actually run additives.
I have cold started my 3500 (accidentally messed with the remote start) , cold soaked at -30C ambient. It cycled the grids once and fired right up. No gelling, no issues.
But I must confess, we in the Prairies are quite lucky. The usual severity of our winter has stations getting winter blend fuels in their tanks quite early. It seems like we run winter fuels from the end of July to usually the first week of July the next year. The cold also keeps a lot of the lefties out as well.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
Page 3 of 3 1 2 3
