Total energy vs Total ineo first
by Goran - 11/20/19 02:22 AM
Fram Ultra - Hot Tub Filter
by SavagePatch - 11/19/19 10:08 PM
Possible bad coil on Husky 150bt
by i6pwr - 11/19/19 09:52 PM
JD LVU800097
by Jason_Michaels - 11/19/19 09:09 PM
Chiappa M1-9
by GumbyJarvis - 11/19/19 09:05 PM
Power steering fluid change out; frequency.
by GeorgeMP - 11/19/19 08:59 PM
2020 Toyota Supra
by Y_K - 11/19/19 08:57 PM
Door hinge pins and bushings
by P10crew - 11/19/19 08:22 PM
future new car prices-gas vs electric
by 1978elcamino - 11/19/19 07:51 PM
Briggs/ Walbro idle tuning
by eljefino - 11/19/19 07:46 PM
Shell Rotella Gas Truck 0W-20, 9349 miles FCA 2.4
by austinlunsford - 11/19/19 06:53 PM
06' V6 Accord 12,462 miles Penzoil Platinum 0W20
by Daschicken - 11/19/19 04:57 PM
Pride Asian Plus Coolant-thoughts?
by N Heat - 11/19/19 04:21 PM
Should it really take this long?
by IronMaidenRules - 11/19/19 02:21 PM
Pdlodge, Cubez007, dshadow, Hansvoytek, DeltaP71
69919 Registered Users
55 registered members (87sammy, alchargo, Amkeer, Bailes1992, 7 invisible), 1,073 guests, and 24 spiders.
Topics297,656
Posts5,120,097
Members69,919
Most Online3,589
Nov 2nd, 2019
2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi #4993786 01/28/19 03:36 PM
d00df00d Offline OP
498 miles on the oil
83368 miles on the engine
Bought this car with just over 80k miles on it and a few thousand left on the most recent oil change. Previous owner had used Shell Helix Ultra Racing 10W-60.
I had the rod bearings changed preventatively (rod bearing wear is a known issue with this engine). At that time, the oil was replaced with BMW TwinPower Turbo 10W-60, which I am continuing to use. The shop advised me that a 500 mile OCI was probably-not-necessary-but-advisable-and-harmless after a rod bearing change, so I did that. This sample is from that OCI.
Not sure where the lead is coming from. Anyone think it could be left over from the old rod bearings? They were lead/copper and rather worn (new ones are apparently aluminum/tin). That was two OCIs ago, though. Man, do I hope it's not from the main bearings...
Pretty sure the fuel dilution was from cold running due to a failing thermostat (just replaced), plus a fair number of short trips.
Copying the numbers here because Polaris's reports are kind of annoying to read:
Iron - 5
Chromium - 0
Nickel - 0
Aluminum - 1
Copper - 0
Lead - 8
Tin - 0
Cadmium - 0
Silver - 0
Vanadium - 0
Silicon - 4
Sodium - 4
Potassium - 1
Titanium - 1
Molybdenum - 54
Antimony - 0
Manganese - 0
Lithium - 0
Boron - 60
Magnesium - 26
Calcium - 2499
Barium - 0
Phosphorus - 861
Zinc - 961
Fuel Dilution - 1.8% (by GC)
Soot - <0.1% by vol.
Water - <0.1% by vol.
Viscosity @ 100º C - 18.6
TBN - 7.06
Oxidation - 9
Nitration - 9
2008 BMW M3 Sedan 6MT
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: d00df00d] #4993792 01/28/19 03:40 PM
rooflessVW Online Content
Online Content
I don't think 8ppm of lead is indicative of anything without a trend. Is this your first UOA or did you do one before the rod bearing change?
"Zed's dead baby, Zed's dead."
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: d00df00d] #4993835 01/28/19 04:34 PM
Z
zorobabel Offline
Z
The engine was taken apart, dust & crap got in, some lead is expected.
1997 Maxima 206k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 205k, VWB 5W-20-30, MGL4967
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: rooflessVW] #4993856 01/28/19 04:51 PM
d00df00d Offline OP
This was the first UOA on this car.
I know numbers don't mean much without a trend, but I don't think there are many sources of lead in this engine. I'm not aware of any other than the (old) rod brearings.
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: d00df00d] #4993860 01/28/19 04:56 PM
F
FlyPenFly Offline
F
I think new rod bearings still need to wear in and might be from that? There might be some lead in the new bearings too.
2014 Mercedes GLK350 3.5L DFI
2014 Mercedes E350 Coupe 3.5L DFI
2010 Audi A4 2.0T
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: FlyPenFly] #4993943 01/28/19 06:22 PM
d00df00d Offline OP
Nope -- the new rod bearings are lead-free.
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: d00df00d] #4993946 01/28/19 06:24 PM
A
ammolab Offline
A
8ppm lead is nothing. My S54 powered M Coupe got new rod bearings when the lead hit 68ppm @ 60,000 miles...and NEEDED them for sure.
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: d00df00d] #4994170 01/28/19 09:39 PM
d00df00d Offline OP
Significant correction: if the lead in this sample had come from the previous rod bearings, that would have been from one OCI ago, not two. Derp. Wish I could edit the OP.
Also forgot to list the particle quantifier (PQ) index of 11.
Anyway....
Assuming that all the lead came from the old rod bearings, that there is no other source of lead in this engine, and that around 10% of the oil system's total capacity was left in the engine, cooler, and plumbing after everything was drained for the rod bearing service... wouldn't that mean the previous oil would have had a lead count in the neighborhood of 80 ppm? I know those are slightly sketchy assumptions; I just want a check on the math.
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: d00df00d] #4994247 01/29/19 12:03 AM
A
Artem Offline
A
I think another 500 mile sample is needed for comparison. Don’t drain the sump, just sample.
Who knows where it’s from but the next UOA will surely help tell the trend.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: d00df00d] #4994293 01/29/19 03:55 AM
G
Gokhan Offline
G
Don't they have other brands of 10W-60? Perhaps, try Amsoil. High lead could be because of some peculiar chemical effect of Castrol 10W-60.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 0,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: Gokhan] #4994526 01/29/19 10:21 AM
d00df00d Offline OP
Just spoke with Polaris about the aforementioned lead number math. Basically, the answer is no; too many variables to say for sure.
Repeating this to be clear: the only reason I'm attending to this 8 ppm lead number is that I'm not aware of any other sources of lead in this engine. So, if there's ANY lead at all in this report, it's residual and/or it means there's something I don't know about this engine.
Good call. Would be nice. Not easy with this engine, unfortunately. There's no dipstick so pulling a sample would necessarily involve draining a few liters of >$10/L oil. Considered a Fumoto valve or something similar, but I don't like the implications for ground clearance...
Yes, there absolutely are other 10W-60s. I'm really not inclined to mess around with oil in this engine, though. My policy is not to stray from OE unless there's a VERY clear and well-demonstrated reason that applies to my specific case, and there's been no such thing for non-spec oil for this car (surprise, surprise).
BMW switched from Castrol to Shell a while back, so TwinPower Turbo 10W-60 is a Shell product. AFAIK high lead isn't a thing for either this oil or the Castrol product.
Re: 2008 BMW M3, BMW TwinPower Turbo 10W-60, 498 mi [Re: d00df00d] #4994716 01/29/19 02:06 PM
G
Gokhan Offline
G
Yes, there absolutely are other 10W-60s. I'm really not inclined to mess around with oil in this engine, though. My policy is not to stray from OE unless there's a VERY clear and well-demonstrated reason that applies to my specific case, and there's been no such thing for non-spec oil for this car (surprise, surprise).BMW switched from Castrol to Shell a while back, so TwinPower Turbo 10W-60 is a Shell product. AFAIK high lead isn't a thing for either this oil or the Castrol product.
Ah, so, it' Shell.
