Back to Basics VI
MolaKule
Staff member
Iowegia - USA
For a barrel of crude oil, what percentage of this barrel would yield a conventional Lubricant base stock after processing?
This question is NOT open to engineering disciplines, Tribologists, chemists, mathematicians, physicists, psychologists, sociologists, or savants.
Originally Posted by newbe46
I like it when we have to start putting disclaimers before beginning any discussions on this board.
Not actually a disclaimer, but in this case we would like all BITOG members who are not listed above a chance to answer.
Do you have a proposed answer?
My thoughts exactly
My research says you basically heat the crude oil and collect the different fractions that boil off at different temperatures. About 1% is used for lubricants.
While I've studied engineering, chemistry, and math, I'm clueless how to calculate this.
A barrel of crude is 42 gallons.
The refining and processing yields a number of products including lubricant base oil which equals 0.5 gallon.
0.5 gallons/42 gallons = 1.2% rounded up.
JayHawkRoy and WalterJay gets the virtual BITOG Mug with the embossed
emoticon and 0.5 gallons of virtual full synthetic oil.
Yes, I understand that but is it the same for all barrels or crude? That fraction is constant barrel to barrel?
We didn't see a numerical answer from you but this information came from the API itself.
I have to assume the yield figure they quoted is an average over many types of crude's and processes, as I think that is what you are alluding to.
