Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
Not on sale but theeeeeeyyyyy're here!
by jayjr1105 - 01/17/20 06:47 PM
Valvoline Daily Protection 5w30 - $13.52 at Walmart
by RonRonnster - 01/17/20 06:39 PM
Gotta love Friday
by 53' Stude - 01/17/20 06:11 PM
It was 1911
by CourierDriver - 01/17/20 06:10 PM
Desulfating a Battery
by 5AcresAndAFool - 01/17/20 05:41 PM
weird deal alert: potassium permanganate
by GON - 01/17/20 04:42 PM
Kirkland Signature 0W-20 any good?
by CB22 - 01/17/20 04:31 PM
F250 airbox
by mobilaltima - 01/17/20 04:10 PM
CPA1989, myisland, BuellRacer, devharryc, UncleNorby
70460 Registered Users
76 registered members (5AcresAndAFool, 2003f7, 2010Civic, 4WD, 2strokeNorthstar, 10 invisible), 1,507 guests, and 30 spiders.
Topics300,264
Posts5,171,942
Members70,460
Most Online3,728
Jan 11th, 2020
Page 4 of 6 1 3 4 5 6
Re: Dual exhaust benefits [Re: DoubleWasp] #4986812 01/21/19 05:27 PM
SubieRubyRoo Offline
Originally Posted by DoubleWasp
It's hasn't been a long time since I have dealt with a person who chose to comment without reading.
At no point in either of my two posts do I EVER address the crossing of HP and Torque at 5252rpm. Only which direction torque goes after 5252rpm and why.
My bad, I was posting at 2am and obviously wasn't thinking well. Apologies.
Re: Dual exhaust benefits [Re: OilUzer] #4986891 01/21/19 06:42 PM
DoubleWasp Offline
No big deal. I've played the part too many times myself, so I can't judge.
crush
Re: Dual exhaust benefits [Re: OilUzer] #4988439 01/23/19 11:23 AM
A
Anduril Offline
A
Who cares about fractional HP or MPG gains when you get that V8 rumble! Need I say more?
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: Dual exhaust benefits [Re: OilUzer] #4988604 01/23/19 02:00 PM
DGXR Offline
Dual exhaust modification on modern vehicles causes abusive noise levels in residential areas that were once peaceful. Any gains in power, torque and efficiency are so small that they simply cannot be justified by the cost of the modification. Thanks to all the "enthusiasts" with noisy street exhaust that "sounds awesome" and require extra attention to be super cool feel better about themselves. Grow up.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Dual exhaust benefits [Re: DGXR] #4988624 01/23/19 02:29 PM
bdcardinal Online Content
Online Content
FWIW I have not had a single complaint from a neighbor about my exhaust. Either with my current Mustang with Borla ATAKs or my 98 GT that had an offroad x-pipe and Spintechs. I also drive very responsibly, actually been yelled at for driving too slow before in the neighborhood. All the dads in the neighborhood seem jealous that I am not stuck with a minivan.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Dual exhaust benefits [Re: OilUzer] #4988645 01/23/19 02:53 PM
DoubleWasp Offline
I have motorcycles, so I never spend any time wondering if my car exhaust offends my neighbors.
Re: Dual exhaust benefits [Re: OilUzer] #4989701 01/24/19 03:16 PM
N
NGRhodes Offline
N
One thing to remember, unless you have moving pipes, you can't have an exhaust that has perfect flow at all RPMs, there has to be SOME compromise and trade off. Depending on the engine this could be a small or high compromise, often the higher the tune (power per capacity unit), the bigger the compromise is.
Also, the exhaust is one part of an air pumping system and dependant on the characteristics of other parts of the engine in that system, some quite complex relationships and dynamics as you are trying to capture continuous intake supply, through cyclic events (piston combustion) and out, whilst trying to meet design aims of economy, emissions, power/torque and noise.
Engines are dynamic, flow and back pressure varies relative to rpm and load. To say lower back pressure is better is fine ideologically, but to put in practise is a hard thing to do, eg optimise for peak power at high RPM and you can (and is often seen when trying to reach peak power with wild cam configurations) reduce advantages of techniques such as of scavenging at lower RPMs, leading to less lower/torque at low/mid RPM and relates to what I mention above about compromise.
When optimising for maximum performance you want to look at the desired common operational RPM of the engine for your use cases and optimise for maximum area under the torque curve in that range - as that is mathematically equivalent to the average maximum torque across your desired rev range which equates to best overall acceleration.
Re: Dual exhaust benefits [Re: OilUzer] #4990073 01/24/19 11:35 PM
DoubleWasp Offline
Indeed. My point was that nobody who knows a lick about exhaust is considering engineering in back pressure.
An exhaust, once properly engineered for it's application may have a certain amount of back pressure, but that was never ever ever the target at all. What back pressure there may be is doing absolutely nothing for the engine at all, and adding back pressure will not do anything at all. Simply the result of engineering that is actually relevant.
One saying back pressure helps an exhaust is taking an inevitable result that was never a factor of design, and assigning it as the cause.
Re: Dual exhaust benefits [Re: DGXR] #4990095 01/25/19 01:27 AM
Skippy722 Online Happy
Online Happy
“People enjoy things that I don’t, therefore they need to grow up! *angrily shakes fist from front lawn*”
There’s obnoxious straight pipes, then there is tasteful. I removed the resonators on my Durango, always got complemented on how it sounded by my neighbors. My brothers Daytona has active exhaust straight from the factory... start it up and the valves open for that sweet sweet v8 start up, then close back off to quiet it back down. Cruising down the road they’re closed, but step on it and it gets loud again.
That being said, some of these motorcycles are down right ridiculous. I’ve heard gun shots quieter than them.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Dual exhaust benefits [Re: OilUzer] #4990124 01/25/19 04:37 AM
U
userfriendly Offline
U
Dual tail pipes from a common single exhaust pipe, is different from a dual exhaust system originating at the engine.
What are we talking about here?
Is the following statement true?
Tuning an exhaust system ( which includes exhaust camshaft timing, valve lift, rate of lift and exhaust valve size) will add torque at a narrow rpm range,
often at the expense of lower torque elsewhere in the engine's operating range.
Obviously we want to increase torque in the rpm range where it will increase the performance of the vehicle.
Retaining heat in the exhaust gasses might be a good place to start.
Re: Dual exhaust benefits [Re: userfriendly] #4990128 01/25/19 04:55 AM
Online Happy
Well, everything works as a system. Tweak the exhaust, naturally you’ll need to tweak the intake. Generally though, you’d have to pick one... you want low end grunt? That’ll cost you power up top. Want maximum power? Gonna cost you some torque.
But the nice thing about newer cars with things like DOHC with VVT and variable valve lift is you can get the best of both worlds. The torque down low, click everything over, and still maintain your power up high. Through all that you get engines like FCA’s 305hp Pentastar V6 that makes 90+% of peak torque from a mere 1800rpm and carry it all the way to 6,350rpm while running on regular 87 octane!
Re: Dual exhaust benefits [Re: OilUzer] #4990132 01/25/19 05:05 AM
U
U
In general with fixed valve timing, do long tube headers and dual exhaust add torque at one rpm range at the expense of torque at another?
Re: Dual exhaust benefits [Re: userfriendly] #4990135 01/25/19 05:22 AM
Online Happy
Yes.
We will assume the headers are the same size in both my examples, let’s say 1 7/8” primaries, and the only difference is the rest of the exhaust.
Narrower exhaust, like our headers dumping into 2” exhaust pipes, will keep the exhaust gas velocity higher resulting in more torque at lower RPM. The issue though is at higher RPM the exhaust becomes a restriction.
Those same headers, dumping into a 3” exhaust, will make more power on the top end, but less torque at low ROM’s.
Re: Dual exhaust benefits [Re: OilUzer] #4991108 01/26/19 04:21 AM
U
U
What about shorty headers? They might not add or subtract torque at different rpm like long tubes. Wrap them to retain heat and run them into a large single exhaust? You could still split the tail pipes for the dual exhaust look.
Re: Dual exhaust benefits [Re: userfriendly] #4991110 01/26/19 04:44 AM
Online Happy
Hot Rod already did a test and has written it far better than I can lol, granted it’s a dual exhaust set up they used, they were ONLY comparing the headers in this test. The rest of the exhaust, assuming you’re not trying to cram it into a tiny little pipe, will have a rather negligible affect on power and torque compared to the headers. True dual, 2 into 1, 2 into 1 into 2 (some ram trucks do this), X pipe, h pipe won’t affect power like the headers will.
https://www.hotrod.com/articles/headers-dyno-test/
