Originally Posted by edyvw
Originally Posted by oghl
Originally Posted by Purpfox
M1 0w40 lists a TBN as 12.6, this should get quite a few miles before its used up. now compared to M1 5w30 of only TBN 6.8.
Viscosity's are very close at 12.9@100c 70@40c with a VI 189 for the 0w40
11.0@100c 61.7@40 with a VIof 172 for the 5w30
someone mentioned the M1 EP 5w30 and it starts with a lower viscosity and not much improvement on the TBN at 8.26
Data provided from either Mobil pds page or my tested results
I think I mentioned earlier that this 0W40 is a step or three above most 5w30. Maybe I should have said it's a step or 5 above
That 5W30 that you guys are talking about is probably step above 0W40.
It is low -SAPS oil for diesel engines and gassers where ULSG is available.
Previous version of that 5W30, M1 ESP Formula 5W30, was arguably best product they had in line up for a long time. Do not confuse that 5W30 with regular ILSAC GF-5 5W30.
Yeah, that low TBN is not for standard M1 5W30...it is usually shown as somewhere between 9 and 10.
