Originally Posted by Donald
Ford, and maybe other car companies have all tires Road Force balanced at the factory. Many/most Ford dealers will have the machine. Other places also.
Ah …… Mmmmm ….. Not exactly.
To my knowledge EVERY car manufacturer requires its tire suppliers to screen tires for uniformity (what Hunter Engineering is calling RoadForce), exclude those that exceed a certain value, and mark the radial HIGH point of the first harmonic. They also require other properties to be screened as well (for example, imbalance.)
They also require their wheel suppliers to screen for runout, exclude those above a certain level, and mark the LOW point of the first harmonic.
In the assembly plant, the tire's high point is matched up with the wheel's low point, so a more round assembly results.
THEN the assembly plant balances the assembly.
Please note that this match mounting is NOT related to balance, but to (more or less) runout.
