Couple days back had some strange idling problem, a random instability.. yesterday I heard the cooling fans rev up on hi and not stop. Today, checked the ECT sensor and it's fine. Noticed some old rat damage on the sheath, wire wasnt broken but insulation compromised. Snipped and fixed it up hoping that's what it was. No luck.
The sensor seems fine, tested with another one also with same reult. Temp gauge works fine, Air/Fuel seems ok so ECU seems to be getting a correct engine temp reading, only problem is cooling fans coming on shortly after the basic warm up, temp gauge rightly shows a slightly low operating temp. It's below freezing outside.
Here's the bizarre behavior. The fans go on high, as they would during a very hot day with the AC going but just after the basic warm up (and at subzero temps). I think it has something to do with the AC system because when I toggle the AC switch, compressor kicks on and RPMs flare a lot higher than they normally would, briefly. Then when I toggle AC switch off, compressor disengages fine but the idle RPMs drop like a rock and become very unstable-- stalling half the time if not settling down after a few seconds.
I'm at a loss right now, is there a temperature switch somewhere in the AC system besides the thermister in the evap coil? What is the logic behind running the fan on high if there is a proper ECT signal? What really gets me is the near stalling when turning off the AC ... any ideas? Starts/runs just fine otherwise..
