Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
29 registered members (Brad_C, bbhero, c502cid, 5 invisible), 531 guests, and 59 spiders.
Topics286,442
Posts4,908,263
Members67,622
Most Online2,967
Mar 10th, 2019
Gravity bleeding brakes #4976311
01/11/19 05:32 PM
01/11/19 05:32 PM
The Northeast
mclasser Offline OP
mclasser  Offline OP
The Northeast
I've usually let my indy shop handle brake fluid changes but the Accord will need front brakes in the coming future and I thought I'd DIY the fluid as well.
I've watched YT vids on the different ways to do this and I feel the most comfortable with gravity bleeding. I know it takes some time, but it doesn't need special equipment and seems to work very well. I don't want to do a traditional pedal bleed and possibly damage the 16 yr old master cylinder. Here are my questions about GB:
- Does the MC cap need to be open or closed during the process?
- Can I crack open all 4 bleeders at once?
- Besides being less messy, is it necessary to fit a tube over the bleeders, or I can I just let them drip bare?
- Do I have to pump up the brakes before cracking the bleeders?
- Do I have to touch the pedal at all during the process?
Any tips you guys can offer will be very appreciated. Thank you!
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Gravity bleeding brakes [Re: mclasser] #4976329
01/11/19 05:57 PM
01/11/19 05:57 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Waste of time imo. Makes bleeding the brakes a real chore.
Gravity: safe but SLOW
two-man: high potential for damage without an experienced foot.
Vacuum is the safest. Might not be perfect but you can always vacuum the junk out and then use another method for the finishing touches.
Power bleeding is the best but not everyone bleeds enough brakes to own one. A vacuum extractor is much more versatile and makes sense for a DIYer to own.
EDIT: Cap open, I am curious if cracking all four at once is better than a single circuit at a time? Just pull the cap, crack the bleeder(s) and let it drip if you want. A hose on the bleeder makes the progress visible. I wouldn't really want brake fluid dripping everywhere, I'm pretty sure I have brake fluid spots on my car from being clumsy with a hose or my hands.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Gravity bleeding brakes [Re: mclasser] #4976337
01/11/19 06:01 PM
01/11/19 06:01 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Me: 13' VW GTI 3 door 6 speed manual
Re: Gravity bleeding brakes [Re: mclasser] #4976339
01/11/19 06:03 PM
01/11/19 06:03 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I've done it several times with good results. I remove brake fluid from the MC, being sure not to suck out too much and allow air into the brake lines, fill it to the top with fresh fluid and cap it. I do the rear wheels first, keeping an eye on the MC and topping up as needed. When done with the rear, tighten up the bleeders put on the wheels and move to the front. I don't touch the brake petal. You can put a hose on the bleeders, I do that and put a large oil catch pan under the rotor. The hoses are cut long enough to clear the rotors and hang about an inch above the catch pan, I bottle it to give an idea of how much each caliper drained. The flow can be controlled via loosening or tightening the bleeder. Mine don't drain very fast. The job can be done with about a quart or so of brake fluid. I usually buy three quarts and do both my Jeeps on the same day.
God Bless Our Troops
Re: Gravity bleeding brakes [Re: mclasser] #4976340
01/11/19 06:04 PM
01/11/19 06:04 PM
Cheshire, England
barryh Offline
barryh  Offline
Cheshire, England
I've only ever gravity bled one wheel at once. I do use a short length of tube into a jar just to keep things clean although there is no need for the tube to be submerged in fluid. If you don't bleed into a jar you have no indication of how much fluid has been bled on that wheel. I keep the cap off the reservoir because you need to keep an eye on it and top it up. Don't touch the pedal at all, You will find a big difference between the flow rate between front and rear wheels with the rears taking much longer. Other extreme is gravity bleeding on the front brake of a motorcycle which is very quick. Low viscosity Dot 4 bleeds faster than the regular type.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
Re: Gravity bleeding brakes [Re: mclasser] #4976342
01/11/19 06:07 PM
01/11/19 06:07 PM
wv
krismoriah72 Offline
wv
Its going to be a small chore getting to all bleeders without removing the wheels. Unless your fluid is contaminated or cooked i would just do the turkey baster method and swap out 3/4 of the fluid a couple or few times.
Re: Gravity bleeding brakes [Re: mclasser] #4976344
01/11/19 06:10 PM
01/11/19 06:10 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Be mindful that brake fluid can dissolve paint.
Re: Gravity bleeding brakes [Re: mclasser] #4976353
01/11/19 06:18 PM
01/11/19 06:18 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Install Russell Speed Bleeders.
Re: Gravity bleeding brakes [Re: mclasser] #4976385
01/11/19 07:02 PM
01/11/19 07:02 PM
South Carolina (SC)
RyanY Offline
RyanY  Offline
South Carolina (SC)
This is the easiest method I have found for replacing fluid or bleeding brakes. My Honda is not back to front, so yours may also have a unique sequence.
https://youtu.be/ag-Q_lP0dOk
2007 Cadillac CTS 3.6L >119k miles (Magnatec 5W-30 + Fram Tough Guard; Maxlife ATF)
2012 Honda Odyssey EX-L >97k miles (Maxlife 5W-20 + Fram Ultra; Pennzoil Platinum LV ATF)
Re: Gravity bleeding brakes [Re: skyactiv] #4976391
01/11/19 07:11 PM
01/11/19 07:11 PM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
This absolutely!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Gravity bleeding brakes [Re: mclasser] #4976417
01/11/19 07:31 PM
01/11/19 07:31 PM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
Your life depends on those brakes! Do you feel qualified to gamble with it?
Re: Gravity bleeding brakes [Re: mclasser] #4976425
01/11/19 07:38 PM
01/11/19 07:38 PM
Hawaii, USA
anndel Offline
anndel  Offline
Hawaii, USA
You get many different procedures so I'll add mine which is a little faster than gravity.
- Start with the farthest wheel and I use a Mityvac vacuum system.
- Remove the MC cover then use a turkey baster and remove some fluid but do not empty and introduce air into the system.
- Remove the wheel, connect the hose to the bleeder then loosen bleeder.
- Pump several times (make sure valve on Mityvac is on vacuum not pressure (can act as a pump on some models).
- Check MC and make sure to keep topped off with fresh brake fluid. Make sure you use fluid your vehicle specifies.
- Pump until fluid is clear and keep MC topped off.
- Go to the next farthest and repeat.
- Check the FSM as you may have to bleed the ABS as well.
- Rinse any spilled fluid on paint with water as it will eat paint.
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - M1 EP 10W-30, Fram UG Filter
2005 Toyota Avalon XL, 3.5L V6, Amsoil SS 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Re: Gravity bleeding brakes [Re: mclasser] #4976478
01/11/19 08:43 PM
01/11/19 08:43 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
I use vacuum but gravity works fine too. I would remove the reservoir and clean it first to get off to a good start.
Re: Gravity bleeding brakes [Re: mclasser] #4976504
01/11/19 09:11 PM
01/11/19 09:11 PM
MN
14Accent Offline
14Accent  Offline
MN
How are you going to hurt the MC by doing a 2 person bleed? Is it because the MC stroke is longer than normal so the seals might catch on some lip in the bore?
I've never once ruined a MC by doing a two person bleed, even on old cars. The only time I've had an issue is when the car comes in with a blown component that caused complete fluid loss. Master's don't like being run dry, but as long as you keep the fluid full I don't see the issue.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Gravity bleeding brakes [Re: 14Accent] #4976512
01/11/19 09:20 PM
01/11/19 09:20 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
I guess... I've heard this about my Honda, so I put a chunk of 2x4 under the pedal to limit the stroke. It still bleeds just fine.
Also, I don't feel snookered by buying, and using, a Mity-Vac. It was all of $35, and I've already used it for more things than I count. Brake bleeding is just one thing. Yes, I use it along with a partner pushing on the brake pedal. The vacuum part just helps make sure I don't drip or leak.
That A1Auto video... pretty good, but I always use a box end wrench on the nipple. Rust belt and all that. A 12 point box end has always been OK here, but the one time I used an open end wrench (was in a hurry) I immediately rounded it off.
Various musings: http://hangfire.net
