While searching for a easier to obtain oil for my '17 Cruze Diesel I was reminded that FCA had changed the oil recommendations for the Ram Ecodiesel to use a API CJ-4 or ACEA A3/B4 or E9/E7. Which have varying degrees of compatibility with filters, nox reduction systems and egr. My Cruze on the other and recommends only Dexos 2 which is built on ACEA C3 specs.r
When FCA changed the specs on the Ram they started recommending Rotella 5W-40 instead.
My question Is, both have DPF, SCR, EGR so would I be ok with running Rotella in my Cruze as well. I only ask because no one in town sells any form on Dexos 2 oil and my Amsoil hookup might no longer be available. I can order Pennzoil Euro L off Walmarts website and have it delivered but if I can just pickup some Rotella instead, it might simplify things.
Any suggestions?
Any suggestions?
